July 1, 2015, 05:18 |
Monitor Statistics CFX 16.0
#1 | |
Rep Power: 11 |
I have some questions about the new functionality Monitor Statistics in CFX 16.0. With a CEL expression it is possible to access Monitor Values (here I use the arithmetic average of an expression) : probe(Expression Value.Arithmetic Average)@exampleLet’s assume that example uses a Moving Interval defined on 40 iterations. When I try to use probe(Expression Value.Arithmetic Average)@example in CEL I have this error message : Quote:
If( Accumulated Time Step < 40, 1 , probe(Expression Value.Arithmetic Average)@example)I have still the same problem. Do you have a solution ? |
July 10, 2015, 10:57 |
Rep Power: 11 |
I have found the solution I post it if others have the same problem in the future. My problem was that my inlet boundary condition depends on the expression probe(Expression Value.Arithmetic Average)@example (defined with a moving interval of 30 iterations). Consequently, the 30 first iterations, CFX can't do the calculation because the value of the expression doesn't exist. The solution is to make an artificial run just to initialize the second calculation. Good bye |
December 2, 2023, 02:20 |
zh
Rep Power: 3 |
Please,Could you tell me how to solved it?
December 2, 2023, 03:38 |
Rep Power: 144 |
Hasn't boubou described exactly what the problem is and how to fix it?
If you do not understand what boubou is saying, or it is not working for you then post a question on that.
December 2, 2023, 03:59 |
zh
Rep Power: 3 |
With a CEL expression it is possible to access Monitor Values (here I use the arithmetic sum of an expression) : probe(Expression Value.Arithmetic Average)@example Let’s assume that example uses a Moving Interval defined on 2 iterations. When I try to use probe(Expression Value.Arithmetic sum)@example in CEL I have this error message : | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine CEL_WRAP | |
December 2, 2023, 04:10 |
#6 | |
Rep Power: 144 |
Did you read boubou's post? It says:
December 2, 2023, 04:19 |
zh
Rep Power: 3 |
Sorry,I can not understand
December 2, 2023, 04:31 |
Rep Power: 144 |
If the function you want is the moving average over 2 iterations, then:
* set up a simulation where you have removed the moving average function. Run it for 2 time steps. * Do a simulation which now includes your moving average function, and use the result file of the first simulation as the initial condition. This should run as you now have 2 time steps of history for the function to average over. Hopefully this works for you.
December 2, 2023, 05:52 |
#9 |
zh
Rep Power: 3 |
Thank you!
I have tried the method you said but still show the error below Follower partition: 5 Follower routine : ErrAction Leader location : Message Handler Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine CEL_WRAP What should I do, please |
December 2, 2023, 06:06 |
#10 |
Rep Power: 144 |
Please post your output file which shows this error.
December 2, 2023, 06:34 |
#11 |
zh
Rep Power: 3 |
[IMG]file:///E:/ANSYS/res/WINKESSEL8-3_059.out[/IMG]
This is my Out.File? Could you help me check it? thank you |
December 2, 2023, 07:13 |
#12 |
zh
Rep Power: 3 |
Monitor Point: Q
Arithmetic Sum Parallel run: Received message from follower -------------------------------------------- Follower partition: 3 Follower routine : ErrAction Leader location : Message Handler Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine CEL_WRAP | | |
December 2, 2023, 19:32 |
#13 |
Rep Power: 144 |
Here is how to attach something to the forum: https://www.cfd-online.com/Wiki/Ansy...n_the_forum.3F
December 4, 2023, 15:12 |
#14 |
Rep Power: 33 |
What version of the software are you running?
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 08:08 |
High Resolution (CFX) vs 2nd Order Upwind (Fluent) | gravis | ANSYS | 3 | March 24, 2011 03:43 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 14:22 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 06:59 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 05:47 |
