June 14, 2015, 10:21 |
A confusing problem at making a wave tank
M S
Rep Power: 11 |
Hello.
I modeled a water tank in cfx. i tried to make waves in the tank by make a moving wall. i move the left wall of the tank around it's bottom point. as like this image: http://i58.tinypic.com/14o7ywh.jpg as you know the wave height must be increased by increasing the angular frequency. (or decreasing the period) after solving the problem every thing is right. but the wave height decreased by decreasing the period. Expressions i defined are these: Xdisp = (y/wavelen)*Af*sin(angularfrec*t) angularfrec = (2*pi)/period period = 1.2[s] wavelen = 2.5[m] Af is "S" in above image. Does anyone Know where my mistake is? |
June 14, 2015, 20:28 |
Rep Power: 144 |
Obviously decreasing the period will not increase the wave height for all cases. Do you think that a very short period would generate waves hundreds of metres high?
When you start getting to short periods then the liquid does not have enough time to refill the volume emptied by the moving wall and the wave height gets small again. I will leave as an exercise for you to work out the maximum wave height versus period |
June 20, 2015, 08:51 |
#3 | |
M S
Rep Power: 11 |
those results show increasing in wave height by decreasing the period. but my work with same conditions shows reverse results. my results for all periods and all courses are same. and waves are in centimeter scale. |
June 21, 2015, 07:30 |
Rep Power: 144 |
Across the entire spectrum, increasing period will not always give larger waves. Across the range of conditions tested in that report it might show increasing period gives larger waves.
Now your question is different - why is my simulation inaccurate? FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F |
cfx, wave tank |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
Wave tank dynamic mesh | Doro | FLUENT | 0 | October 27, 2011 05:39 |
active wave absorb(about wave tank) | zhaochuangang | ANSYS | 0 | September 22, 2010 03:29 |
Mass conservation problem in mixing tank multiphase simulation | rockewan | FLUENT | 0 | April 6, 2010 13:34 |
UDF for sine wave in tank & cell count questions! | A8anato_psofimi | FLUENT | 0 | February 9, 2004 05:00 |
