In CFX-post, how to obtain the mass flow rate of a cross section
Like Tree3Likes
  • 1 Post By mz_uon
  • 1 Post By Opaque
  • 1 Post By pavlenty
Old   April 30, 2015, 09:47
Question In CFX-post, how to obtain the mass flow rate of a cross section
Bruce Xiao
xyq916 is on a distinguished road
In CFX-post, how to obtain the mass flow rate of a cross section?
xyq916 is offline   Reply With Quote
Old   April 30, 2015, 19:34
Go to function calculator and choose the massflow function.
Old   January 23, 2022, 18:19
mz_uon is on a distinguished road
Hi Glenn
I want to calculate the volume flow rate through a zone. I am unable to find a function to do that. Any suggestions?
Thanks
mz_uon is offline   Reply With Quote
Old   January 23, 2022, 18:30
I presume by "zone" you mean a boundary face.
For simple flat faces volume flow rate is areaInt(Normal Velocity)@Zone Face, where you replace Normal Velocity with the velocity direction and Zone Face with the appropriate name. You can do curved faces as well, but they will require a bit more thought.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   January 24, 2022, 11:04
Thanks for your reply. Correct, I have found this across several documents.
However, I am confused when it comes to actual selection of the surface and/or velocity. See the attached snapshot. The 2 methods give different answers, whereas I imagined it should give the same volume flow. What is the difference between them?
Regards
Old   January 24, 2022, 11:44
Opaque will become famous soon enough
In the first one, you are asking for
Area integral along Z direction of the velocity magnitude
on the second one, you are asking for the
Area integral of Velocity along the Z direction
Opaque is offline   Reply With Quote
Old   January 24, 2022, 13:57
So which one is the correct value for volume flow through the window? I observed two formulae in literature (see image), does any of my earlier expression calculate this?
Ersin11 likes this.
Old   January 24, 2022, 14:51
Neither of those is correct (generically). The formalism is
massFlow()@Boundary / Density
or you could also create an expression
VdotN = Velocity u * Normal X + Velocity v * Normal Y + Velocity w * Normal Z
then
areaInt (VdotN)@Boundary
I assume you are working with an incompressible fluid (constant density) since volume flow rate does not mean much (to me) for compressible fluids.
Ersin11 likes this.
Old   October 18, 2024, 07:59
pavlenty is on a distinguished road
To calculate massFlow()@Boundary, CFX determine velocity, normal to boundary?
pavlenty is offline   Reply With Quote
Old   October 18, 2024, 08:18
then
What is the point of VdotN ? This is the velocity. But you should give the velocity, normal to selected boundary due to determine mass flow rate.
Ersin11 likes this.
Old   October 18, 2024, 15:20
Perhaps you should read the documentation. The suggested expression VdotN would be evaluated at the boundary of interest for the function. For example,
areaInt(VdotN)@Inlet will use velocity and Normal at the boundary named Inlet
areaInt(density*VdotN)@Inlet will use density, velocity and normal vector at the boundary named Inlet.
cfx mass flow rate
CFX turbo - Mass flow rate Vashishth Patel CFX 7 April 3, 2014 21:33
Convergence problem with target mass flow rate ADL FLUENT 2 May 29, 2012 22:11
Discrete Phase & Mass Flow Rate MagnusZeus FLUENT 0 December 2, 2011 18:57
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 07:44
How to obtain mass flow rate of one phase Derek Jing FLUENT 1 May 31, 2002 14:18
