problem in making animation of movement water? |
April 24, 2015, 16:17 |
Hydreaulic structures
Rep Power: 15 |
hi dear all
i want make animation of movement water in my model, i making isosurface of movement water, but my goal is movement 3d water on model not in form surface like figure shown, i read tutorial but unfortunately my problem dont solved, what should define for do this? thanks in advance |
April 25, 2015, 07:07 |
Rep Power: 144 |
I do not understand your question. What are you trying to do?
I can see your mesh is still very coarse. You are not going to get accurate results with that mesh. |
April 25, 2015, 07:16 |
Rep Power: 15 |
hi dear ghorrocks
yes i I have noticed my mesh is coarse and i have modifiying it, but i have another question in this case animation of water movement, i want see movement water in model with thickness not in form isosurface,i do need for other model, my mean is movement water as shown figure, for do this i what should defined in cfd-post? thanks a lot |
April 26, 2015, 20:16 |
Rep Power: 144 |
I still do not understand your question.
Are you trying to see the motion of the water? The isosurface will not move much as the water passes underneath it. The normal way to see the velocity of the fluid is using vectors. You can also use markers on streamlines to animate with the flow. |
April 28, 2015, 03:42 |
Rep Power: 15 |
thanks for answer dear glenn
my mean is movement of water in model or animation of movement water , i do this animation with isosurface, as shown figure, the movement of water in form is surface, i want seen thickness of water in animation?? how do this?? best regards hamid Last edited by hamidciv; April 28, 2015 at 12:56. |
April 28, 2015, 03:54 |
Lance
Rep Power: 22 |
Use an isovolume instead of isosurface if you want to see the "thickness" of the water. Have you tried Insert > Volume/method: isovolume ?
April 28, 2015, 12:57 |
Rep Power: 15 |
dear lance, thanks a lot
problem with two phase flow (air injected in water) | miles_davis | OpenFOAM | 15 | March 31, 2021 10:36 |
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 05:03 |
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 15:27 |
Getting the pressure waves in Fluent for a water hammer problem | teopetre | FLUENT | 2 | August 6, 2013 20:24 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 06:18 |
