Flow driven of darrius turbine using ANSYS cfx |
April 8, 2015, 15:48 |
TKP
Rep Power: 11 |
At present i am trying flow driven analysis( Turbine is rotated by fluid motion) to estimate performance of vertical axis Darrieus turbine in ANSYS CFX/ANSYS Fluent. But i am unable to perform. Is FSI is needed for analysis? I am NOT concerned about deformation of turbine blade. so I am taking turbine as rigid body.
April 8, 2015, 18:51 |
Rep Power: 144 |
Do not model this with FSI. Do not model this with rigid bodies. Use a rotating frame of reference. Examples of how to do this are in the CFX tutorials, all the rotor/stator cases.
A lot of people are making this mistake. I think we should write an FAQ on this. |
April 9, 2015, 04:54 |
TKP
Rep Power: 11 |
Thanks a lot..Can you please provide me the link of one such tutorial? Thanks again ]
April 9, 2015, 05:38 |
Thomas MADELEINE
Rep Power: 12 |
Look at Help -> Tutorial
and then you have the choice of many of them with stator/rotor or just rotor, compressor/turbine, axial/radial... just pick one that describe the best your simulation ^^ |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
ANSYS CFX: Produce swirling flow using cylindrical components | neilduffy1024 | CFX | 4 | August 7, 2013 09:00 |
CFX - Solidworks Flow, Impeller comparison | aerospace_guy_ | CFX | 8 | March 20, 2012 23:06 |
Boundary condition setting regarding turbine simulation using CFX | Lacerlacer | CFX | 11 | March 12, 2012 10:32 |
simulation Axial flow turbine using CFX | dia aisa | CFX | 3 | May 2, 2008 03:45 |
