script to check convergence in live during a run launched in batch mode |
March 13, 2015, 04:02 |
Véronique Penin
Rep Power: 12 |
Good morning!!!
Since yesterday, I am using a cluster for my calculation. Before that, I'm using the workbench, and I was checking convergence with CFX solver manager and its automatic drawn curves. How can I draw convergence curves in live in batch mode? Can someone give me a script which draw the same curves as in CFX Solver windows (I think based on the file.out)? Thank you and have a nice day, Véronique |
March 13, 2015, 05:01 |
Lance
Rep Power: 22 |
If you can start cfx5solve on your cluster you can monitor the running job directly: 'monitor run in progress', select the .dir folder
March 13, 2015, 05:04 |
Rep Power: 144 |
Load up solver manager and click on open CFX run in progress. Select the directory of the run in progress - it will have a name like .tmp_dir(run name) or something like that.
March 13, 2015, 06:02 |
thanks ;)
Véronique Penin
Rep Power: 12 |
Sorry, I think my question was confused.
On the cluster, I can't use the workbench, because I have no graphical interface. In my repertory, I have just CFX.def, CFX_001.out, CFX.def, and CFX_001.dir in which I have cfx5.interp.ccl cfx5.tt, cfx5.mms def mms mms.setup mms.setup.attrb mode.dat mon mon.old out phst par ccl and 1400_full.bak (my back up file, at iteration #1400). But I can access to my repertory by another cluster with a graphical interface. I open solver manager by the workbench, then select job.err (created by my script to launch the job), and I select Run In Progress and then CFX_001.dir. Thanks for the idea. Véronique |
March 13, 2015, 06:08 |
Rep Power: 144 |
Start CFX in stand alone mode, not through workbench. Use the CFX launcher to start solver manager and do as Lance and I suggested in our previous posts.
March 13, 2015, 11:15 |
Rep Power: 33 |
To add to Glenn and Lance's suggestions.
You can start the CFX in stand alone mode on another computer that can access the same filesystem used by the cluster; therefore, you comply with the cluster requirements, and you are also able to monitor, or post-process intermediate backup/transient files if you need to. |
batch mode, cfx, cfx solver manager, convergence |
Running Ansys in BAtch Mode | kuleuvenstudent | ANSYS | 1 | October 18, 2017 13:11 |
Run ansys 12.0 using batch mode (windows xp) | mayan | ANSYS | 2 | May 25, 2016 09:02 |
cfdpost in batch mode | taichijulie | CFX | 1 | October 25, 2010 16:29 |
DM Script / Batch mode | Anantha | CFX | 0 | October 22, 2007 09:47 |
batch run | N.R. | CFX | 1 | June 17, 2007 23:44 |
