Simulation by ansys cfx for a ceilng fan balde
Like Tree4Likes
  • 2 Post By monkey1
  • 1 Post By monkey1
  • 1 Post By ghorrocks
Old   March 11, 2015, 06:27
Default Simulation by ansys cfx for a ceilng fan balde
Pang Chun Wai
wai325 is on a distinguished road
I wan simulating a ceiling fan for my final year project.
I using ansys cfx for it.
Is it correct that i using Immersed solid as the fan when setting up my simulation? and how can I set the rotational direction? I only able to set the rotating axis but i not sure either it was rotating in clockwise or anticlockwise.
And how can i plot a velocity graph to calculate the flow rate under the fan?
Hope some experts can help me...thx
wai325 is offline   Reply With Quote
Old   March 11, 2015, 06:35
monkey1 is on a distinguished road
Immersed solid has some serious constraints as to the applicable cases.
I would solve this problem by putting the fan in a cylindrical domain, that is connected to the rest by interfaces. Then I would define the cylindrical domain with the fan as rotating domain with the desired rotational speed.
wai325 and boloko like this.
monkey1 is offline   Reply With Quote
Old   March 11, 2015, 06:54
Pang Chun Wai
What u mean by using a cylindrical domain? I have enclosed my fan with a cylinder and setting it as the fluid domain. I was new in ansys simulation, and I was following this tutorial.
https://www.youtube.com/watch?v=l5IJEpPDyxs
how can i set my rotational direction? or any other advise? thx for ur info.
Old   March 11, 2015, 08:50
I Mean that ur fan is included in a (small) cylindrical domain that covers just the fan geometry. That cylindrical (and rotating) domain is then included in a bigger static domain representig your fluid that should be set in motion by the fan (maybe the picture attached shows better what I mean.
And to define a rotation you have to define the cylindrical part as separate domain. There under the basic settings tab you have the ioption "DOmain Motion" where you can define a rotational axis as well as a rotation speed.
The Direction of the rotation is according to the right hand rule, meaning:
if Z is the rotation axis then a positive roattion speed makes the whole thing rotate from the postitive x-axis to the positive y axis anticlockwise
if y is the rotation axis then its from the z to the x anticlockwise
and for x as axis its from y to z anticlockwise.
Was this what you wanted to know?
wai325 likes this.
Old   March 11, 2015, 15:47
Pang Chun Wai
i have set it to rotate anticlockwise as wat i wan. and nw the result showing me hw the airflow. May i know hw can i obtain the velocity graph or table to show me the volume flow rate of the ceiling fan that i designed?
Old   March 11, 2015, 18:45
Monkey is right, this should be done using rotating frames of reference; not an immersed solid model (this seems to be a common mistake on the forum, several people make this mistake it appears....)
Do the CFX tutorials on rotating machinery, for instance the rotor/stator models. They show how to model turbomachinery. That will give you the basic idea of how to model your fan.
boloko likes this.
ghorrocks is online now   Reply With Quote
Old   March 12, 2015, 00:34
Pang Chun Wai
where can i get the tutorial for RFR? and is it the cylindrical fluid volume enclose the fan is rotating or the fan domain is rotating?
Old   March 12, 2015, 00:38
Pang Chun Wai
Is it mean that i have to create a cylinder jz enclose my geometry and follow by a box enclose all of them to be the static fluid domain?
Old   March 12, 2015, 02:37
Yes you have the Fan cylinder and around ambient air in a box (or whatever shape desired) domain, if you want to model the effect of the fan on the sourrounding atmosphere.
Old   March 12, 2015, 03:39
Pang Chun Wai
Do you have any tutorial on setting the cylinder to be rotating frame? then i have to set the fan to be solid domain?
Old   March 12, 2015, 04:08
Got not tutorial sorry.
You do not need to model the fan. Just model fuid domains, where the fan is "empty space" and the surfaces representing the fan are then marked as Wall Boundaries.
As I told you to define the fan domain you just have to define the "Domain Motion" on the basic settings atb of the domain definition where you can define a rotational axis as well as a rotation speed.
FSI simulation in ansys cfx Arash67.m CFX 1 September 29, 2017 10:52
Verifying results for a wind turbine blade simulation in ANSYS CFX Joystix CFX 3 April 27, 2012 18:52
Boundary condition setting regarding turbine simulation using CFX Lacerlacer CFX 11 March 12, 2012 10:32
Fan Blade Simulation. 2D CFD with FLUENT? CFX? aerospain ANSYS 0 December 3, 2010 07:08
ANSYS to acquire CFX Fred Siemens 0 February 18, 2003 22:03
