Vertical Velocity at results
Like Tree1Likes
  • 1 Post By ghorrocks
Old   March 9, 2015, 19:40
Default Vertical Velocity at results
ki
ejdrlqja is on a distinguished road
I am trying to read vertical velocity data of the monopile foundation of wind turbine in results but probe seems to only show velocity not vertical velocity. When i plot the contour of velocity u or w, it only shows in the contour legend and max and min value. How can I get the exact value of vertical velocity at the bottom of the monopile structure?
Thank you for your help!
ejdrlqja is offline   Reply With Quote
Old   March 10, 2015, 05:06
Use a probe to put the sampling point exactly where you want it. Then use the function calculator to extract the value at that point.
Veronique Pe likes this.
vertical velocity
Comparing Air numerical results with water experimental results cristian2009es Main CFD Forum 1 July 2, 2014 19:11
velocity in a specific point in cfx results ja.maldonado1187 CFX 1 February 13, 2013 20:58
Results from a software for CFD that uses FEM HectorRedal Main CFD Forum 0 January 19, 2011 11:30
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
how to print the results from CFX-4.2 cfd_99 Main CFD Forum 5 June 21, 1999 10:23
