February 27, 2015, 15:04 |
full moment of inertia or half?
Henry Arrigo
Rep Power: 16 |
Hi all,
I want to model a rigid body motion. I am going to take the advantage of the symmetrical nature of the problem and just model the half of geometry. So my question is should I use the full moment of inertia and mass in my simulation or half moment of inertia and half of mass? Thanks |
February 28, 2015, 07:42 |
Rep Power: 144 |
If you are using symmetry you should halve it.
April 15, 2018, 13:22 |
Gautami Erukulla
Rep Power: 17 |
Dear Mr. Horrocks,
To simulate a floating cylinder (using 6DOF rigid body motion solver) with symmetryPlane option, dividing the computational domain into half, does the mass and moment of inertia of cylinder defined in the dynamicMeshDict be divided to half. Taking full mass sinks the cylinder. Kindly please advise. Thank You. Most&More, Gautami Erukulla. |
April 15, 2018, 13:34 |
Gautami Erukulla
Rep Power: 17 |
Dear Mr. Horrocks,
To simulate a floating cylinder (using 6DOF rigid body motion solver) with 3 DOF motion in heave, surge and pitch, and be restrained with linear spring, should the spring stiffness be taken half value for half the domain using symmetry plane option. Kindly please advise. Thank You. Most&More, Gautami Erukulla. |
April 16, 2018, 07:23 |
Rep Power: 144 |
You appear to be using OpenFOAM. Try the OpenFOAM forum.
April 16, 2018, 09:30 |
Gautami Erukulla
Rep Power: 17 |
Dear Mr. Horrocks,
Thank you for your reply. Will do as suggested. Most&More, Gautami Erukulla. |
March 6, 2021, 15:18 |
Center of mas annd moment of inertia
Deutschland
Rep Power: 6 |
Hey,
I am simulating a ship. Due to symmetry I am only working with half of the geometry. for Dynamic mesh I have following doubts 1. centre of mass - the centre of half or full geometry 2. moment of inertia -moment of inertia of half geometry or (moment of inertia of full geometry)/2 Thanks in advance vava10 |
March 15, 2021, 03:31 |
Erik
Rep Power: 23 |
COM should be original location (on symmetry plane)
It should also be moment of inertia of full geometry / 2. Though this should be the same as half the geometry since the center of mass should be specified as the same. |
March 15, 2021, 06:21 |
half geometry
#9 |
Deutschland
Rep Power: 6 |
I have few more question in dynnamicMeshDict 1. rhoInf : what exactly is this value? In some ship simulation cases it is one and in one I saw it was assigned the value of density of water. 2. In DTCHullMoving the setup uses the entire geometry for meshing even though one half of the geometry is analysed. Does this affect the values of mass entries in DynamicMesh Thanks in advance |
March 15, 2021, 19:12 |
#10 | |
Rep Power: 144 |
Please refer to post #5:
How to calculate Mass moment of Inertia for 6DOF | vigii | FLUENT | 3 | February 22, 2017 06:29 |
Changing moment of inertia | frownless | STAR-CCM+ | 1 | August 15, 2013 22:12 |
Mass moment of inertia | Cluain | CFX | 4 | July 18, 2012 10:36 |
Center of pressure (confirmation/question) | scipy | FLUENT | 2 | March 5, 2012 07:54 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
