January 7, 2015, 06:43 |
Adaptive Time Stepping: First Update Time
Mr CFD
Rep Power: 15 |
I'm running a transient simulation from t = 0s until t = 1200 s (20 minutes).
I don't care about the first 5 or 10 seconds as the results are usually garbage - in this period the simulation is just starting up and I want to overcome the initial transient. The adaptive time stepping scheme tries to find an ideal time step at all times. To avoid this I've set the first update time to 10 seconds, using an unusually large time step to quickly overcome the initial transient. After 10 seconds the adaptive time stepping bit kicks in converging within 5 - 10 coefficient loops (it's multiphase). What are your thoughts on my strategy to avoid solving the initial transient? |
January 7, 2015, 06:54 |
Rep Power: 144 |
As long as the poor resolution of the initial transient does not affect the later fluid flow then it sounds fine. What you describe is very common in compressible flow simulations as acoustic waves bounce around everywhere when the simulation starts up. If you don't care about this just use some big timesteps to get through it quickly.
January 7, 2015, 07:09 |
Mr CFD
Rep Power: 15 |
Thanks. I thought this was the case.
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
number of iterations per time step | chouki | FLUENT | 1 | August 13, 2013 01:11 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 23:40 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
