December 15, 2014, 06:09 |
Impulse pressure
Loris
Rep Power: 13 |
Hi everyone,
I have to start off with my master thesis. I have to study a injection pipe with a known nominal pressure which is exposed to impulse of pressure. How can I set these impulse in Pre-Window of CFX? Thank you for your responce |
December 15, 2014, 07:09 |
Rep Power: 144 |
Define an initial condition in the domain of the starting pressure. At a pressure inlet apply a different pressure. Make the fluid compressible (eg ideal gas), the time step small enough to catch what is happening and let it go. You should get shock waves bouncing all over the place.
December 15, 2014, 07:12 |
Loris
Rep Power: 13 |
Ok! Thank you very much!
impulse pressure, pressure |
Pressure Driven Supersonic Flow in Converging-Diverging Nozzle | cdm | OpenFOAM Running, Solving & CFD | 7 | August 28, 2019 02:37 |
How to get the total pressure in the UDF? | zgzhai | Fluent UDF and Scheme Programming | 3 | September 24, 2018 17:12 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
replacing of shock tube high pressure part with a boundary condition for low pressure | immortality | Main CFD Forum | 0 | May 2, 2013 14:30 |
Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 13:41 |
