ERROR #001100279 has occurred in subroutine ErrAction.
Like Tree2Likes
  • 1 Post By Opaque
  • 1 Post By gusano154
Old   December 12, 2014, 03:12
Default ERROR #001100279 has occurred in subroutine ErrAction.
Aniseh
aniseh is on a distinguished road
I'm simulate transient, multicomponent gas inside a containment, no heat transfer. I want the code to solve mass, momentum, TurbKE, Diss.K and mass fraction equations. But I get the error "| ERROR #001100279 has occurred in subroutine ErrAction". I've checked out the physics of the simulation, initial conditions, etc,. but I coud'nt solve the problem...
What does the error mean?? [ The error appears in the first itteration, and I ran the solver using HP MP1 local parall].
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Compression of block failed because compression is switched of at |
| all. |
| Message: |
| Stopped in routine COLL_COMP_BLKS
aniseh is offline   Reply With Quote
Old   December 12, 2014, 04:02
Aniseh
when I run the solver using series mode, the simulation is running, but i got the following information before the 1st step itteration...
| Writing transient file 2_full.trn | | Name : Transient Results 1 |
| Type : Standard |
| Option : Timestep Interval |
| Message: |
| Warning: formatted floating point data is only written to single-- |
| precision accuracy |
| Message: |
I want to use HP MP1 local parallel, unfortunately i got error as I said before, is memory causing problem? how can I fix it?
Old   December 12, 2014, 05:17
These are very unusual errors, I have not seen them before. CFX does not explain its error messages very well, does it?
The serial error is strange as it appears to happen when writing a results file. What happens if you don't write the results file?
You are just going to have to guess and turn a few things on and off the find the source of the error. If you feel lucky you can post your CCL on the forum and we can have a look but I give no guarantees that will identify the problem either.
Old   December 12, 2014, 09:54
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
I am suspecting not enough memory...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   December 12, 2014, 15:04
Opaque will become famous soon enough
As the message says:
Warning: formatted floating point data is only written to single precision accuracy
You must have modified the settings about data compression under OUTPUT CONTROL, did you not ? Try reverting to its default state and post back.
What version of ANSYS CFX are you running ? HP MPI has not been supported for a while. Are you referring to Platform MPI ?
Hope the above helps,
DaveD! likes this.
Opaque is offline   Reply With Quote
Old   December 15, 2014, 02:15
Aniseh
Hi again,
The problem is solved, as Opaque mentioned before, I've modified the settings of file compression under OUTPUT CONTROL to default.
I'm running ANSYS 12.0.1 version, HP MPI is supported by this version.
At the beginning, the code can't ran the simulation using HP MPI mode because of the C driver was out of space. The problem solved when I made enough free space on the system drive..
Thank you very much for all your help and useful information
Old   October 5, 2015, 12:01
Armando E. Kitto
gusano154 is on a distinguished road
I was getting the "formatted floating point data is only written to single precision accuracy" warning, and I was able to solve it changing compression to default under OUTPUT CONTROL. Thanks a lot Opaque!!
DaveD! likes this.
gusano154 is offline   Reply With Quote
ERROR #001100279 has occurred in subroutine ErrAction. wangy1767 CFX 36 July 25, 2020 07:09
ERROR #001100279 has occurred in subroutine ErrAction. smnaryal CFX 11 December 20, 2017 17:32
ERROR #001100279 has occurred in subroutine ErrAction. sujay CFX 8 December 10, 2014 13:09
ERROR #001100279 has occurred in subroutine ErrAction. | | Message: sujay CFX 1 June 10, 2013 23:30
ERROR #001100279 has occurred in subroutine ErrAction. P9408 CFX 1 August 19, 2009 08:56
