real stack memory problem
Like Tree2Likes
  • 1 Post By ghorrocks
  • 1 Post By Opaque
Old   October 29, 2014, 12:48
Default real stack memory problem
Sharon Wilcox
CFDturbomachinery is on a distinguished road
does anyone know how to get rid of this error in CFX? I am using 1.4 memory allowcation factor but still showing this error.
*** INSUFFICIENT MEMORY ALLOCATED *** |
| ACTION REQUIRED : Increase the real stack memory size. |
| Details : |
| Requested space : 2785716 words |
| Current allocated space : 48516696 words |
| Current used space : 47089570 words |
| Current free space : 1427126 words |
| Number of free areas : 3
CFDturbomachinery is offline   Reply With Quote
Old   October 29, 2014, 18:27
If you increase the allocation factor but still get the error then you have a fundamental error in your setup. Something is causing the problem - examples include excessively complex GGI interfaces, file names too long, too many boundary surfaces, too many phases, and zillions more causes.
CFDturbomachinery likes this.
Old   October 30, 2014, 08:49
Opaque will become famous soon enough
You must try to understand the message to see if you are making progress by allocating additional memory.
It says:
Therefore, it tried to use 2785716, but it only has 1427126 available, i.e. it is off by about 50% in available memory. In addition, it says that the available memory is divided in 3 free areas; therefore, even if the Current free space was large enough, there may not be a single free area large enough for the request.
Try a larger memory factor, and see how the message guides you. If you see no progress, or unrealistic request review your setup carefully, or contact ANSYS CFX support.
Opaque is offline   Reply With Quote
Integer stack memory insufficient mactech001 CFX 1 May 15, 2014 07:22
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 06:08
udf error Rashmi FLUENT 0 December 27, 2005 06:35
Integer stack memory size Twiti CFX 2 December 22, 2004 08:38
CFX 5.6 memory problem with solver sreevisakh CFX 3 February 2, 2004 05:57
