How can I check imbalance?
Like Tree1Likes
  • 1 Post By AliMadayen
Old   October 12, 2014, 17:23
Default How can I check imbalance?
Sangwoo Kim
swtbkim is on a distinguished road
Hi all.
I'm simulating about fan.
But result is not reasonable, and I was advised to check imbalance.
He said that I can check imbalance in solver window, i.e. CFX-Solver manager like RMS, Turbulence, and so on.
I searched several manuals, but I couldn't find.
I'm nearly new to CFX, and actually I didn't understand even what imbalance means
Any help will be highly appreciated.
Thanks in advance!
Best regards
swtbkim is offline   Reply With Quote
Old   October 12, 2014, 19:15
Ali Madayen
AliMadayen is on a distinguished road
Hi
When the solver run is finished, the final values for imbalance are reported in the reports shown at the end.
But if you wish to monitor them during thee run, you should add a new monitor for that. Right Click on the upper tabs of the workspace (Like momentum and mass tab) and click on the "New monitor". Ok in the appearing windows, then in the next windows check the boxes for the equations which you want to monitor their imbalance. and click apply. I suggest you to change the monitor axis type to the log scale in the middle tab, cuz you can observe their variation better this way.
Experts should comment on the physical meaning of the imbalance, but as far as I know imbalance means the net difference between boundaries of a domain for each variable. my experience is, an imbalance of 0.1 or less might denote a converged solution.
Best
Ali
ssmacae likes this.
AliMadayen is offline   Reply With Quote
Old   October 18, 2014, 17:32
Sangwoo Kim
Sorry for my late answer.
Thank you very much. I have checked imbalance near fan.
I'm simulating two fans.
Front fan is OK, but back fan is the problem.
Imbalance of back fan is oscillating in the range of +- 5%.
Do you know about this phenomenon??
I totally don't know what I should do..TAT
Thank you.
Best regards
Old   October 19, 2014, 06:23
Run your simulation for longer to allow it to converge tighter. If it is not converging then refer to this FAQ: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Problems with mass imbalance kannstmasehn STAR-CCM+ 3 July 26, 2013 04:38
[ICEM] Understanding check mesh output kotimari ANSYS Meshing & Geometry 0 July 15, 2012 09:33
faceZones and topological check mturcios777 OpenFOAM Programming & Development 0 June 15, 2012 14:48
Automated check for convergence Chander CFX 3 May 2, 2012 19:07
Cell check and Boundary check errors AB Siemens 4 October 28, 2004 14:04
