How we can determine convergence by the imbalances of the equations?
Like Tree2Likes
  • 1 Post By ghorrocks
Old   October 1, 2014, 17:52
Default How we can determine convergence by the imbalances of the equations?
Ali Madayen
AliMadayen is on a distinguished road
Hi Everyone
I remember reading some posts regarding the problem that CFX has some problems with very fine meshes. right now i'm working on a problem and I'm checking grid independency of the results.
In the coarse meshes, solution easily converges. But as I make the mesh finer, residuals do not fall below a certain value and begin to alter around that specific value, without decreasing. As I make the mesh finer, this certain value Increases.
However, the domain Imbalances in all cases are very small for all equations. Like 0.3%, at most.
now the question is, can I consider my solution converged, when the residuals are about 1e-4 but imbalances smaller than 1?
P.S. I searched the from as much as I could. I hope I'm not posting a repeated question.
P.S. 2: The problem is cavitation in a minichannel. i've used physical timescales as small as 1e-6, yet the residuals do not decrease more than a certain amount. I use Rayleigh-Plesset model. and these results have good consistency with experimental images of the cavitation region. I just wanna make sure i'm not faking the validation.
AliMadayen is offline   Reply With Quote
Old   October 5, 2014, 08:33
As you refine the mesh the result is probably becoming transient. So you will probably need a transient simulation to fully converge it.
AliMadayen likes this.
Old   October 12, 2014, 19:51
Ali Madayen
Tnx for your reply.
So you mean that the imbalances alone are not reliable? I just want to grab the concept of that.
I heard someone saying that the sum of cut-off error in fine mesh prevents the solution from being fully converged. Is that true?
Old   October 12, 2014, 20:01
It is not as simple as that. It is discussed in this FAQ: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
The imbalances alone are generally not a reliable measure of convergence. That is why the equation residuals is the default convergence criteria - it is more generally applicable, but even it is not universally applicable.
Yes, round off error can prevent tight convergence. But so can many other things too.
Old   October 13, 2014, 07:36
Ali Madayen
I got what I wanted.
Thanks a lot.
Guide: Writing Equations in LaTeX on the CFD Online Forums pete Site Help, Feedback & Discussions 27 May 19, 2022 04:19
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 10:48
accelerate the convergence entropie OpenFOAM Running, Solving & CFD 2 October 10, 2014 19:58
Time step dependence of convergence behavior of steady state simulations in CFX Chander Main CFD Forum 5 December 23, 2013 06:31
convergence parameters amv Phoenics 4 September 21, 2005 07:49
