Reference State Properitues
Like Tree1Likes
  • 1 Post By ghorrocks
Old   July 21, 2014, 03:41
Default Reference State Properitues
Cafard
Cafard is on a distinguished road
Hi all,
I have some questions with Reference State Properitues.
When I read CFX-Pre Guide I found the fpllowing paragraph:
"When defining specific heat capacity, you must set a reference temperature and reference pressure.
These quantities are used only to define a reference level from which some derived quantities, such as
a change in enthalpy or entropy, are calculated. The defaults for these values are 1 atm and 25°C.
However, you should set these values to values that are representative of the average temperature and
pressure that will occur in your model.
You should also consider table limits as well in that it is better
to choose reference values that fall in the valid range for table property generation. "
The original setting is 297.15 K & 1 atm.
If my working fluid doesn't reach the refernce state,
should I change the setting?
Cafard is offline   Reply With Quote
Old   July 21, 2014, 07:01
The reference pressure should be set to a typical pressure present in your simulation. Likewise the reference temperature should be a typical temperature.
Old   July 21, 2014, 07:24
Cafard
excuse me
what's the typical state??
If my working pressure at 1 Mpa~ 2 Mpa,the typical pressure is still 1 atm??
Old   July 21, 2014, 07:54
No. Then your reference pressure should be something in the range 1MPa-2MPa.
Cafard likes this.
wmake problems during custom utility compilation palazi88 OpenFOAM Programming & Development 11 August 13, 2018 21:52
OF211: ThirdParty and /src compiled, but not /applications... vkrastev OpenFOAM Installation 8 October 18, 2012 16:53
libnurbs++ kuczmas OpenFOAM Running, Solving & CFD 7 May 14, 2012 07:33
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile val46 OpenFOAM Installation 4 August 27, 2010 04:43
Building OpenFoAm on SGI Altix 64bits anne OpenFOAM Installation 8 June 15, 2006 10:27
