July 12, 2014, 10:43 |
Problem with Convergence (Over flow)
Rep Power: 12 |
Hello everyone.
I´m trying to simulation the flow in a turbine but I get only over flow problems in the solver. -Inlet stationary domain (A) then to a rotor (rotary domain B) and finally to the outlet which form part of the same domain (A). -Multiphase transient. 2D analysis (its 3d but only 1 layer depth) -65,000 nodes Inlet 1 - velocity (air) Opening 1 - Opening Pres and Dirn. (0 Pas.) only for air Outlet 1 - average static pressure -I have tried countless times to finish a simulation but I always get this Overflow error. I´m simulating with very small time steps equivalent to every 5 degrees of rotation of the rotor. (timestep: .0029 s) and with a total time of 0.21 s which is the time that takes for only 1 revolution. max 10 iterations, transient scheme: second order backward euler, Advection scheme: High resolution, convergence criteria RMS 1E-4. - Since the problem requires to have a water level inside the turbine (below the runner) I incorporated an expression for the volume of fraction for the stationay doman: Waterlevel=-235mm, WaterVolumefraction= if(y<Waterlevel,1,0) -I have tried with Double Precision/Normal, Parallel(2,4,8,12)/serial, but always around the same time step (65-75) i get the overflow problem. Any idea what could be the problem?? (I tried the same mesh before with steady state and worked, and before introducing the volume fraction equations; but i don’t see any problem with them) Thank you very much in advance! |
July 13, 2014, 07:36 |
Rep Power: 144 |
Have you read the FAQ? http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
What makes you think a 5 degree rotation is a small timestep? It sounds like a huge one to me. Your time step will need to be much smaller than that. |
July 14, 2014, 03:30 |
Rep Power: 144 |
You have reduced your time step size from huge to big.
Have you done a sensitivity study of your time step size? You need to make the time step smaller until your results do not change. I would expect this would give you a time step of more like 0.5 degrees or maybe less if you have a fine mesh. |
July 14, 2014, 04:48 |
Rep Power: 12 |
Hello ghorrocks
My only further plan was to make a Mesh quality study but since you mentioned it, now it makes total sense to include the timestep duration into it. Thank you for your advice. |
Convergence Problem icoFoam steady flow over an airfoil | Lucas | OpenFOAM Running, Solving & CFD | 6 | July 12, 2018 15:06 |
Swirl flow convergence problem with simpleFoam | iqbalsk8 | OpenFOAM Running, Solving & CFD | 7 | November 28, 2012 00:54 |
convergence problem with compressible flow | S.B.J. | Siemens | 2 | February 2, 2009 04:05 |
Convergence problem with compressible flow | S.B.J. | Siemens | 2 | January 7, 2009 03:29 |
Problem with Convergence at high flow rates | Syed | Siemens | 1 | April 10, 2007 15:18 |
