cfd solver
Like Tree1Likes
  • 1 Post By Martin_Sz
Old   June 24, 2014, 02:41
Default cfd solver
mahdi
mahdidelfan is on a distinguished road
hi
my domain is a quarter of the original geometry of supersonic wind tunnel.wind tunnel mach number is 1.8 . in my domain Using tow symmetry boundary conditions and tow wall boundary condition and a boundary condition input and an output boundary condition my simulation cfx Boundary conditions is:
ANALYSIS TYPE:
Option = Steady State
TURBULENCE MODEL:
Option = k epsilon
BOUNDARY: inlet
FLOW REGIME:
Option = Subsonic
END
HEAT TRANSFER:
Option = Static Temperature
Static Temperature = 300 [K]
END
MASS AND MOMENTUM:
Option = Total Pressure
Relative Pressure = 1.8 [bar]
TURBULENCE:
Option = Medium Intensity and Eddy Viscosity Ratio
END
BOUNDARY: outlet
Boundary Type = OPENING
Location = outlet
FLOW REGIME:
Option = Subsonic
END
HEAT TRANSFER:
Opening Temperature = 300 [K]
Option = Opening Temperature
END
MASS AND MOMENTUM:
Option = Opening Pressure and Direction
Relative Pressure = 84000 [Pa]
END
TURBULENCE:
END
wall
HEAT TRANSFER:
Option = Adiabatic
END
MASS AND MOMENTUM:
Option = No Slip Wall
END
WALL ROUGHNESS:
Option = Smooth Wall
END
After 1600 itration cfx solver stop solution .
The error is in the attached image:
Please Help me, please
Thanks for all
mahdidelfan is offline   Reply With Quote
Old   June 24, 2014, 03:26
Martin_Sz's Avatar
Marcin
Martin_Sz is on a distinguished road
Try to define inner type of outlet
you can make mass flow on inlet and outlet (if you know values of these BC).
The next step is to increase memory allocation in solver (default 1). You can increase to 3.
mahdidelfan likes this.
Martin_Sz is offline   Reply With Quote
Old   June 24, 2014, 03:27
Martin_Sz's Avatar
Marcin
Or so You can change to static pressure on outlet
Old   June 24, 2014, 03:43
mahdi
hi
Martin
Thanks for the answer
I do not know the mass flow inlet and outlet. But by placing the static pressure at the outlet boundary conditions arise during Solve backflow
Why is this form of residuals?
And why the solution is stopped?
Old   June 24, 2014, 03:45
mahdi
I am using the quick processing center. Many computing cores is 28 digit
Old   June 24, 2014, 03:49
mahdi
What do you mean?
Old   June 24, 2014, 05:23
Martin_Sz's Avatar
Marcin
Inner like mass flow, static pressure etc.
Old   June 24, 2014, 05:27
Martin_Sz's Avatar
Marcin
your solution is stopped because You have high velocity on inlet - and that makes high pressure on domain. So on the outlet you have overflow.
You can also change solver model (turbulence) to SST.
Old   June 24, 2014, 12:13
mahdi
by solver model (turbulence) to SST i can not capture normal shock in the duct.in the inlet velocity is ~=68 m/s
pesudeo shock, shock train, shock-capturing, wind tunnel
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 20, 2015 00:40
deviation in calculated force between CFX solver and CFD post murx CFX 2 April 9, 2014 21:03
solver for CFD analysis of heat reduction of water in cooling tower using Openfoam? 13msmemusman OpenFOAM 0 March 26, 2014 13:39
2d CFD solver for convection dominated flows Tiziano Main CFD Forum 1 October 10, 2006 07:00
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 18:25
