Rep Power: 12 ![]() |
Hello guys,
I am simulating a centrifugal compressor consists of rotor and stator zones via Ansys CFX 15. when I wanna run the calculation I face with an error which says: '' a negative element volume has been detected ... '' type is steady state and I examined with both stage and frozen rotor models. Also, grid was created by Pointwise software. I would appreciate if someone could help me. ![]() |
Rep Power: 144 ![]() ![]() ![]() ![]() |
This error is common in ICEM when people smooth the mesh too much in the mistaken belief that more smoothing is good. I do not know Pointwise/Gridgen very well, but I presume it has the same trap.
I recommend you remesh and do little or no mesh smoothing. |
many thanks for your consideration.
When I wanna run this problem without any rotation part, I mean I try to just check either it works or not, it works without any error, but when I use turbo mode and define centrifugal compressor,.... after all this error is shown. |
cfx, element, negative, volume |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
Negative volume Detected in Dynamic Mesh after 1500 time steps | abhinavgupta88 | Main CFD Forum | 2 | September 17, 2012 20:55 |
[ICEM] there is NEGATIVE ELEMENT VOLUME in UNSTRUCTURED mesh. | octorisca | ANSYS Meshing & Geometry | 1 | January 13, 2012 09:26 |
Dynamic Mesh, negative volume! | ROOZBEH | FLUENT | 2 | June 22, 2006 20:51 |
