aliali
Rep Power: 12 ![]() |
Hi
I need to define symmetry for the yellow and blue edge to decrease time simulation. I can do it for the yellow parts (fluid) but I dont know how I can do it for the blue edge (my rigid body). thanks. |
Rep Power: 144 ![]() ![]() ![]() ![]() |
I am not sure what restrictions there are in symmetry for rigid bodies - you would have to look that up.
But you can impose symmetry by constraining the motion. If you constrain the motion to only be vertical and stop the relevant rotations then you have imposed symmetry. |
aliali
thanks ghorrocks
I did my simulation in two ways. for the first time I simulated my model completely without using symmetry for the right side of my domain (yellow and blue parts) and for the second time I did it and put symmetry only on the yellow part that has shown in the picture. I did not change the center of mass and weight of my wedge in both of them. there is a little difference between results. what is your opinion? I do my simulation completely (without symmetry) or use symmetry and ignore the difference between results? thanks |
As always, that depends.....
How big is the difference between the results? Is it big enough to be significant? Numerical simulations never give exactly the same answer. Assuming the difference is significant - then is the model in both cases correct? Was the symmetry correctly applied? Is the simulations accurate for what they tried to model? Assuming it was correctly modelled - then is it showing that the flow is in fact not symmetric? For instance, like a vortex street coming off a cylinder. |
6dof model - floating body | flinde | FLUENT | 13 | March 6, 2021 14:32 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
[ANSYS Meshing] Simple Symmetry Mesh Question - Flow around Bluff Body | Matlab69 | ANSYS Meshing & Geometry | 20 | April 23, 2012 09:55 |
Forces in Symmetry | Matt | CFX | 2 | February 25, 2009 05:41 |
