Negative value for static enthalpy calculation in CFD Post |
April 29, 2014, 03:01 |
Bostjan
Rep Power: 17 |
Anybody know what exactly means negative value for static enthalpy in CFD Post?
I have seen in material definition and the reference state is 25 C and 1 atm. For example: areaAve(Static Enthalpy)@Outlet = -1.53639e+006 [J kg^-1] areaAve(Static Enthalpy)@inlet = -2.5098e+006 [J kg^-1] areaAve(Static Enthalpy)@Burner_1_Air_inlet = -2198.38 [J kg^-1] |
April 29, 2014, 04:33 |
Rep Power: 144 |
Negative enthalpy simply means the enthalpy is less than the reference value. It is the differences in enthalpy which are important.
April 29, 2014, 05:03 |
Bostjan
Rep Power: 17 |
Where is possible to check the enthalpy for standard material (for example CO, CO2, H20, N2, O2,...) at reference state if material properties is selected in NASA Format?
April 29, 2014, 08:50 |
Rep Power: 144 |
You define the reference point in the materials tab.
April 29, 2014, 08:53 |
Bostjan
Rep Power: 17 |
I know. I have defined reference point at 25 C and 1 atm but I need to know the value for enthalpy at defined reference point - which value for standard materials (CO, CO2, H2O,....)if material properties is selected in NASA Format. How is possible to get this value?
April 29, 2014, 18:22 |
Erik
Rep Power: 23 |
Like Glenn said, the value is arbitrary, it is based off some arbitrary zero point. If you want to match something, NIST RefProp is a great source for fluid properties. I.m sure there are tables in textbooks and online as well.
April 30, 2014, 01:25 |
Rep Power: 33 |
Check your material definition, and reference state settings.
Under Material: MyMaterial, there should be a section named Reference State, and you can set, or check the following: Reference Temperature Reference Pressure Reference Specific Enthalpy Reference Specific Entropy If your material uses the NASA format to define the specific heat capacity, the reference state is implicit within the coefficients, and you will have to evaluate the NASA expression at the reference state (usually 25 [C] and 1 [atm].. |
April 30, 2014, 02:41 |
Bostjan
Rep Power: 17 |
If under Material select reference specific enthalpy: -1.15334e+07 J/kg and reference specific entropy: 0 J/kgK at reference state 25 C and 1 atm, what is the value for specific enthalpy and entropy at 100 C? same value?
April 30, 2014, 03:53 |
#9 |
Rep Power: 33 |
A quick look at the ANSYS CFX Solver Theory Guide / Basic Capability / Documentation Conventions / Variable Definitions / Static Enthalpy will help understand how all the pieces are connected.
It explains how static enthalpy is computed for the different materials, and how the reference value is used. |
Plotting the Viscosity Contour in CFD Post | ashtonJ | FLUENT | 3 | June 2, 2015 13:06 |
Collect transient results CFD POST | mortain | CFX | 15 | April 17, 2015 09:29 |
How can I include scalable text in my images from CFD post? | ziggo | ANSYS | 0 | October 31, 2013 12:36 |
FEA results in CFD Post | delaneyluke | CFX | 1 | October 25, 2013 07:16 |
CEL mathematical functions in CFD Post | Jonathan | CFX | 9 | November 5, 2012 09:37 |
