Modeling internal flow with normal velocities on walls- permeable walls
Like Tree2Likes
  • 1 Post By ghorrocks
Old   April 27, 2014, 08:07
Default Modeling internal flow with normal velocities on walls- permeable walls
Ali Madayen
AliMadayen is on a distinguished road
Hi everyone.
I'm trying to simulate blood flow in a vessel, where the boundary condition on wall for u is no slip, but for v is a constant definite value. In other words, wall is permeable in y direction. How can I apply this kind of boundary to my problem in CFX?
Tnx for your help
AliMadayen is offline   Reply With Quote
Old   April 27, 2014, 19:27
I presume you mean u is in the tangential direction and v is in the normal direction.
The easiest way of doing this would seem to be a normal no-slip wall with a mass source/sink applied to the wall which gobbles up fluid at your prescribed rate.
dengdeng likes this.
Old   April 27, 2014, 19:35
Ali Madayen
Tnx for your reply
your assumption is correct.
But now the question is what is the relation between source/sink intensity and the normal velocity?
Question is posed regarding that the problem specifies the normal velocity on the wall, and nothing more.
Old   April 27, 2014, 19:55
Make the magnitude of the mass sink a function of the wall shear stress. I would not make it a function of normal velocity as it will then be mesh dependent.
AliMadayen likes this.
Old   April 27, 2014, 20:05
Ali Madayen
Real Smart.
I will try it for sure
Old   April 27, 2014, 20:06
Ali Madayen
Real smart, I will try it for sure
Thanks a lot, friend.
normal velocity, permeable wall
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
flow modeling and incompressible analysis of internal flow of effervescent injector umar959 FLUENT 0 November 15, 2011 04:32
Modeling of water infiltration into a tank containing a permeable soil idir CFX 8 September 16, 2011 07:40
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
