About CFX simulation
Like Tree3Likes
  • 1 Post By Abou ali
  • 1 Post By ghorrocks
Old   April 11, 2014, 18:16
Default About CFX simulation
Yidir AGAWA
yidiragawa is on a distinguished road
Send a message via Skype™ to yidiragawa
Hi everyone.
I've to simulate the fan of the CF680-A3 turbofan at an altitude of 35000ft (cruise regime).
The question is about the fluid to take into consideration, will it be Air ideal gas or Air at the corresponding conditions of pressure, temperature, viscosity ...etc ???!
Thank you.
yidiragawa is offline   Reply With Quote
Old   April 11, 2014, 18:29
Abou ali is on a distinguished road
In CFD practice, fans are simulated by using incompressible gas so you can use air with constant proprieties at the corresponding altitude.
yidiragawa likes this.
Abou ali is offline   Reply With Quote
Old   April 12, 2014, 06:37
I totally disagree. If this question is about an aircraft engine at cruising speed the compressibility effects will be significant and so will need compressible flow. I have no idea what CFD practice you are referring to.
Constant properties (of an ideal gas) will be OK for general work, but if you are looking for high accuracy you may well need to consider variable properties for viscosity, specific heat etc.
Old   April 12, 2014, 08:12
Yidir AGAWA
the fluid must be compressible, since I have to simulate a TRANSONIC fan (in ANSYS CFX 15.0) , at a height(altitude) of 35000 ft
Old   April 12, 2014, 08:20
The simplest compressible model is ideal gas. If you add variable properties to that (viscosity, specific heat) it does not add much to run time and makes it a little more accurate. The next step in complexity is a real gas model and that is much more accurate and much more difficult to successfully simulate. But start with the simple ideal gas model and only if you show that it is inadequate should you consider the more complex models.
Old   April 12, 2014, 08:31
Yidir AGAWA
thank you very much ghorrocks for you thorough replies !
Blast simulation with ANSYS CFX or FLOW-3D etc. xji ANSYS 0 November 30, 2012 17:57
CFX vs FLUENT for particle tracking simulation iman ANSYS 2 August 31, 2012 21:34
Problems on H2/air CFX simulation xulixian OpenFOAM Running, Solving & CFD 2 April 14, 2009 16:00
2D simulation - ICEM meshing for CFX question Ben Makhal CFX 5 April 11, 2007 09:44
Simulation of turbine cascade in CFX. Jonas Pedro Caumo CFX 0 December 9, 2006 14:54
