W component of the momentum equation and its validity in 2D simulations |
Mr CFD
Rep Power: 15 ![]() |
In a "2D simulation" how important is it to achieve satisfactory convergence in the linear solver for the W component of the momentum equation?
In the linear solver if I have an "ok" for the w momentum (as apposed to OK) is this acceptable? Will there be any knock on effects to the u and v components which are more important? (When you read the momentum equations you can see u, v and w are clearly intertwined! But is the w component able to significantly effect the result if the domain is only one cell thick in the w direction!) |
Rep Power: 144 ![]() ![]() ![]() ![]() |
It is not very important to get the linear solver to converge on w. So if you have "ok" rather than "OK" then I would not be concerned.
Mr CFD
Thanks for the reply.
