March 21, 2014, 06:47 |
export boundary condition
lauda
Rep Power: 13 |
Hello there,
I'd like to extract the flow field at the outlet of a radial turbine rotor to be used as inlet condition for a diffuser with a circular inlet section (the diffuser has a squared outlet section so unfortunately I can't use periodic conditions). I've ran steady-state analysis for the turbine. In CFD Post I can generate the full annulus solution at the outlet (please see the figure attached). However when I go to export and select the variable I need, the file that is generated clearly contains only the solution in the single passage. Is there any way to extract the flow properties from the full annulus outlet section? Thanks for any help |
March 21, 2014, 10:10 |
#2 | |
Kevin Hoopes
Rep Power: 17 |
March 21, 2014, 13:11 |
lauda
Rep Power: 13 |
Thanks! I was looking for something similar in CFD post..
cfd - post |
Unable to install OpenFOAM 1.6-ext | Maimouna | OpenFOAM Installation | 23 | May 8, 2014 06:47 |
conjugate boundary condition | Daniel_Khazaei | OpenFOAM Programming & Development | 0 | December 31, 2013 14:11 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
domain imbalance for enrgy equation | happy | CFX | 14 | September 6, 2012 02:54 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
