Problem with Minimum Face angle output using Macro
Like Tree1Likes
  • 1 Post By Lance
Old   November 15, 2013, 01:23
Default Problem with Minimum Face angle output using Macro
Dynampally Pavitran
pavitran is on a distinguished road
I am facing a weird problem and unable to understand it. When I try to calculate the Minimum face angle of domain using Function calculator in CFD post GUI, it returns the value.
minVal(Minimum Face Angle)@sp
27.9536 [degree]
where domain is "sp"
The same, when I am trying to extract through a macro, I defined it as:
! $spminangle = minVal("Minimum Face Angle", "sp");
The output is : 0.488, what could be the problem?
Rest of the values extraction works well, like areaAve("Pressure","inflow");
pavitran is offline   Reply With Quote
Old   November 15, 2013, 03:29
Lance
Lance is on a distinguished road
For some reason the macro outputs the degree in [radians] instead of [°].
0.488*180/pi = 27.96°
pavitran likes this.
Lance is offline   Reply With Quote
Old   November 15, 2013, 04:24
Default Thank you
Dynampally Pavitran
Thank you very much Mr.Lance for your quick reply and keen observation.
Frankly speaking I banged my head three times to my computer, because the answer was too obvious. I think I need to increase my frequency of coffee.
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 07:16
udf problem.. output data comes out to "zero" startup0820 Fluent UDF and Scheme Programming 3 August 16, 2012 00:09
Tide angle problem when meshing Tudor Miron CFX 4 March 22, 2004 18:24
