Aiir bubble in water
Like Tree1Likes
  • 1 Post By ghorrocks
Old   November 11, 2013, 07:12
Post Aiir bubble in water
AKHILESH S L
AKHILESH S L is on a distinguished road
HI,
i need to model air bubble in water and need to find out whether the air bubble is escaping during the circular motion of water through a exit provided at a datum higher than the inlet? can anyone please guide me in anyway for modeling the same? thank you in advance
AKHILESH S L is offline   Reply With Quote
Old   November 11, 2013, 17:17
Do the tutorials provided with CFX - especially the multiphase ones, then do some study on appropriate models.
AKHILESH S L likes this.
Old   November 12, 2013, 11:10
AKHILESH S L
THANK YOU ghorrocks...I WILL TRY ON IT...
Old   November 12, 2013, 11:17
Exclamation mass-flow rate problem
AKHILESH S L
ghorrocks...one more thing i felt in cfx regarding mass-flow rate...we have given a mass flow rate in a face in any problem and analysis is done. after that while checking the the flow rate in the same face in the results i am not getting the given mass-flow rate instead a very low mass flow rate.
i will specify it - i have given a mass flow rate in the outlet of the centrifugal pump and analysis is done .while checking the results it is found that the given flow rate is not obtaining in the outlet y so? if we have given an input it should be the same after the analysis in ordinary cases na? what is the real problem?
while giving the pressure input there is no problem...the given input is exactly showing after the analysis also...
Old   November 12, 2013, 18:00
Can you post your CCL?
air bubble, mixed flow., water
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
I want to rotate secondary phase (bubble in water tank) huseyin Fluent UDF and Scheme Programming 0 May 5, 2010 04:00
Modelling of bubble merging submerge on water Carlos Main CFD Forum 0 October 26, 2005 10:30
Hot gas bubble collapse in cool water William Palm FLUENT 1 April 20, 2005 11:53
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
