when I change the position of the arfiole cfx not converge? |
October 12, 2013, 08:31 |
wadoud
Rep Power: 16 |
hi evry one
I want to study the influence of several vanned distributor opening, so I changed the position of the airfoile, for the first case I got the solution, but when I changed the angle for the other cases the cfx did not converge, although I kept the same mesh (hex type , bloking the same) and the same boundary conditions. Here the picture best regards thank you. |
October 13, 2013, 02:25 |
Rep Power: 144 |
Did you generate new meshes for each position, or use something else?
It could be the first condition is attached flow and the simulation converges easily, but the others are separated flow and convergence is harder in this case it crashes. If this is the case you will need to improve mesh quality, smaller timesteps, double precision or a better initial condition. |
October 14, 2013, 06:26 |
wadoud
Rep Power: 16 |
thank you for reply
for the first case with a 13 ° angle I got the solution for several boundary conditions after 1500 itirations, but when I changed the angle of the blade either 15,18,20 or 25, after 3000 itiritions the residual target is higher than 0.001 and the convergence critiria is 0.00001 to remedy this first I kept the same blocking and I associated the edges and vertices, after I checked the quality of the mesh. second I used a new hex mesh (new blocking). I kept the same boundary conditions. but the problem persists. if you have any ideas or solutions to this problem I am very grateful for your help |
October 14, 2013, 06:40 |
#4 | |
Lance
Rep Power: 22 |
So it doesnt converge when you increase the angle of attack? You probably get separation, and as Glenn said:
October 14, 2013, 06:53 |
wadoud
Rep Power: 16 |
thank you for reply
how can I eliminate this problem to obtain the solution in the different positions of the blades best regards |
October 14, 2013, 06:56 |
Lance
Rep Power: 22 |
October 17, 2013, 06:25 |
wadoud
Rep Power: 16 |
thank you for reply and I am very grateful;
I took your advice into consideration so I changed the mesh, timestep, double precision, I kept the same boundary conditions as the first case, but the problem persists. if you need more details I will disponoble. best regards |
October 17, 2013, 06:34 |
Rep Power: 144 |
Have a look in the literature for what other people have done for these simulations. Have a look at the meshes they use, the timesteps they need and the turbulence models they assumed.
If it is still not converging you need an even better quality mesh and/or even smaller timesteps. The FAQ has more details: http://www.cfd-online.com/Wiki/Ansys...gence_criteria |
October 19, 2013, 06:19 |
#9 |
wadoud
Rep Power: 16 |
hi
thank you for your help and kindness here some details boundary conditions. (inlet): total pressure: 1.6258 bar, total temperature: 333K (output of the rotor): Static pressure: 0 (wall) adiabatic turbulence model used: RNGK-e physical timescale: 3e-06 [s] I used a hex mesh -the height of the first cell was 0.1. to remedy this I kept the same boundary conditions I have increased the number of nodes to 687375 -physical timescale becomes 1e-08 [s] -the height of the first cell becomes 0.05 -Double-precision -I check the quality of the mesh (see picture) I am very grateful for your help |
October 20, 2013, 21:16 |
#10 |
Rep Power: 144 |
You are reporting just one mesh quality metric - and not a very important one at that.
The important ones are aspect ratio, volume ratio, face angle. My post #8 still lists the important things for you to consider. |
October 23, 2013, 06:18 |
#11 |
wadoud
Rep Power: 16 |
thank you for your quick and accurate response.
concerning the quality of the mesh I attached a picture and I hope that you'll clear up the thing |
October 23, 2013, 08:11 |
#12 |
Rep Power: 144 |
Are you doing this steady state or transient? Separated airfoil flow is hard to model steady, so you might need a transient approach, and there is a chance you will need DES/SAS/LES.
October 26, 2013, 05:39 |
#13 |
wadoud
Rep Power: 16 |
hi
thank you for your help and kindnes i used steady state; best regards |
Comparison of fluent and CFX for turbomachinery | Far | CFX | 52 | December 26, 2014 19:11 |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 03:20 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
Phase Change in CFX | derrek | CFX | 0 | June 9, 2003 19:27 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
