September 4, 2013, 12:22 |
Ansys bladegen
hi
Rep Power: 14 |
Hi
I want to create batch file for Blagegen. Can anyone help me to create this? Thank you for your help |
September 4, 2013, 16:39 |
Bruno
Rep Power: 21 |
Batch file as in something that executes several steps in BladeGen?
What exactly do you want to do? |
September 5, 2013, 03:40 |
hi
Rep Power: 14 |
In an algorithm of optimization, we must change the angle of the airfoils and then solve it, I want to create batch file and change the angle.
I must create batch file for solve and post processing in next step! |
September 5, 2013, 15:50 |
Bruno
Rep Power: 21 |
Ok, but doing that through BladeGen is trully not the best option.
Is your geometry going through DesignModeler? If it is, do the blade rotation in there. It is also a lot easier to create parameters in DM then it is to create a script with BG. BTW, you should've posted this in the Meshing & Geometry forum, not here. |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 06:52 |
Fluid structure interaction | jnattia | Main CFD Forum | 25 | May 21, 2015 10:16 |
ansys bladegen | gdeshmukh11 | Main CFD Forum | 1 | January 14, 2013 09:02 |
[Other] Need Help With Ansys BladeGen | luai | ANSYS Meshing & Geometry | 2 | June 19, 2011 11:19 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 02:10 |
