August 2, 2013, 11:15 |
rough wall
Hi experts.
I'm modeling a two phased flow water and air. I have rough wall with roughness of 4 mm. depth of water is about 10 cm and the velocity is nearly 4.5 m/s. I use k-e turbulent model. how much should be the distance of the mesh grid from the wall? |
August 3, 2013, 07:05 |
Rep Power: 144 |
Do a mesh resolution sensitivity check and find out for yourself. There are no shortcuts - we can only guess and that is just a starting point. From there you have to refine it with a sensitivity check anyway.
August 3, 2013, 16:30 |
thank you very much.
[blockMesh] StitchMesh on two patches | anita | OpenFOAM Meshing & Mesh Conversion | 31 | April 4, 2013 12:51 |
Is wall ajacent temperature equal to conservative temperature of the wall? | shenying0710 | CFX | 8 | January 4, 2013 05:03 |
strange solver behavior---Treatment of Rough Wall | Yi | CFX | 6 | April 14, 2010 19:31 |
Rough walls and SST (CFX11) | Sans | CFX | 2 | October 3, 2007 07:12 |
the law of the wall for rough surface | maximus | Main CFD Forum | 0 | January 31, 2004 09:45 |
