NOT equal HEAT FLUXES at two sides of SOLID-FLUID interface ??!! |
July 26, 2013, 11:11 |
Hossein
Rep Power: 13 |
Hi every Body Here !
I am modelling CHT in a pipe. the outer surface of pipe is subjected to constant heat flux. my problem is that when i check the results, the values of HEAT FLUX at two sides of SOLID-FLUID interface are not equal. about 400 W/M^2 difference !! but the values of temperature are equal at each side. I tried to model, using FLUENT software, i found that the value of diffrence is about 1 W/M^2 ..... ! any Idea ?? what would be wrong and what would be solution?? 1- mesh problem? 2- interface adjustments?? 3- CFX software accuracy?? 4- ..... Thanks in advanced |
July 26, 2013, 12:22 |
Some questions to your case and things you should take care...
Jan
Rep Power: 13 |
Hi.
How did you get the values of the heat flux? Please check this case in the ANSYS CFX Solver by defining a new monitor and selecting Flow >> Domain Interface >> ... >> T Energy and H Energy. Another way is to stop the run and watch the out file. If you have an fluid-solid interface, you should always use the GGI intersection method (should be default setting). Do you have defined any energy sources? Have you specified a temperature depended specific heat capacity? Can you approximate the edge length ratio of the mesh at the interface? Regards, Jan ------------------------- Jan Smedseng CFX Berlin Software GmbH |
July 26, 2013, 15:28 |
Hossein
Rep Power: 13 |
I got this values in CFD-Post: Calculator TAB ==> Function Calculator , & using the following expressions :: areaAve(Heat Flux)@Fluid_Solid interface Side 1 areaAve(Heat Flux)@Fluid_Solid interface Side 2 If you have an fluid-solid interface, you should always use the GGI intersection method (should be default setting) What would be the effect of using a 1:1 interface or automatic method?? Do you have defined any energy sources? Have you specified a temperature depended specific heat capacity? NO dear Jan Can you approximate the edge length ratio of the mesh at the interface? I got confused, what should be check?? |
July 26, 2013, 17:42 |
Heat flux balance.
Jan
Rep Power: 13 |
Hi.
please use "areaInt(Heat Flux)@Fluid_Solid_Interface 1 Side 1/2" for calculating an balance. Can you also check the global bilances in the Solver manager? Please check the "Conservative" values of the area integral of heat flux on both sides of the interface. Try also the variable "wall heat flux". A 1:1 connection becomes instable, if the gradient of the diffusion coefficient of the connected domains is to high (e.g. thermal conductivity or specific heat capacity between fluid and solid). The wight of one side in the discretisation is to large. Only use the 1:1 connection, if you have the same material on both sides. That is my personal experience. But that is also the default setting, when using "automatic". So, "Automatic" ist ok :-) Regards, Jan |
July 27, 2013, 07:24 |
Rep Power: 144 |
Nice answer Jan.
On the original question - if the meshes on both sides of the interface do not match then a naive averaging of heat fluxes (with simple area average) will result in the two sides not matching, due to the way the temperature is integrated over the face. The area Ave does not use the full control volume integration points, but the solver does in the GGI so you will get a difference in the two approaches. Can you post an image of the interface mesh, and you say you get a 400 W/m^2 difference - but over what total heat flow? |
Another Boundary Condition to The Fluid Solid Interface | octavyo | CFX | 10 | April 10, 2017 16:57 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Heat transfer between solid and fluid | Suyash26 | ANSYS | 4 | April 22, 2013 15:59 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
