July 19, 2013, 11:47 |
setting two interface
Hi experts.
I'm trying to model a rectangular channel with a weir in the middle of it. I defined 3 body in ICEM with two interfaces. But when I set interfaces a message says that I used one domain in two interfaces settings and it is related to domain placed in the middle of channel. Did I do it wrong? how can I fix it? |
July 19, 2013, 19:16 |
Rep Power: 144 |
Why do you need to use interfaces at all? Can you show an image of your geometry?
July 20, 2013, 05:08 |
Because I use three types of mesh in this channel and I can't merge them.
July 20, 2013, 07:04 |
Rep Power: 144 |
You can still model this with a single domain, but you will need GGI interfaces to join the mismatched grid interfaces up. Note that ICEM has some pretty useful tools for matching the mesh up which would mean you can make this a contiguous mesh with no need for GGIs.
Note that a single boundary face can only be used in 1 GGI. So if the outer boundary is a single GGI it will not work, you will have to split it into an upstream and a downstream boundary. |
July 20, 2013, 12:39 |
#5 | |
July 20, 2013, 18:26 |
Rep Power: 144 |
In ICEM you will have to make one boundary for the first interface, another for the second and I would do another one for the top and another for the bottom as well.
This is basic use of ICEM - have a look at the ICEM tutorials. Also the geometry and meshing forum is best for this type of question. |
July 21, 2013, 05:14 |
Thank you glenn.
I know how to create boundaries. I set three domains with two interfaces. But when I set interfaces I have to use middle domain twice and CFX says every domain should be used in one intrface whereas it's common in both interfaces. Last edited by feizaghaee; July 23, 2013 at 17:14. |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
