CFX POST Geometry Scaling
Like Tree1Likes
  • 1 Post By singer1812
Old   July 10, 2013, 06:38
Default CFX POST Geometry Scaling
monkey1 is on a distinguished road
HI!
Is there a way to scale a geometry in CFX Post?
I have simulated a pipe with 0.015 m Diameter and a Length of more than 1 m.
For a better visualisation I wish to "shrink" the length to 25% or smth. just for Visualisation pruposes without affecting e.g. the Diameter.
Is there a known Way to do this?
Thx!
monkey1 is offline   Reply With Quote
Old   July 10, 2013, 10:56
Edmund Singer P.E.
singer1812 is on a distinguished road
For all objects, go into the object window details, there should be a VIEW tab. Under the view tab there is a scale. Check that and adjust as you see fit.
The scale applies to X,Y,Z coords, so for simplicity, hopefully your geometery lines up.
monkey1 likes this.
singer1812 is offline   Reply With Quote
Old   July 11, 2013, 05:01
Thx a lot!
Exactly what I was looking for!
Though as an explanation for any one else (because I needed some try to figure it out myself ):
If you want to draw a plane to show e.g. the pressure repartition it is sufficient to edit the "View" Tab of the "Plane" and define there a scaling factor <- this what singer1812 meant when mentioning the object window details
No need to try to scale all geometry parts
Allthough one notice: The geometry will not follow / line up.
Thx again singer!
cfx post, geometry, scaling
Two way FSI post processing in CFX ashli217 ANSYS 0 May 3, 2013 06:43
Heat Release in CFX Post kapopadu CFX 0 April 12, 2013 08:33
CFX Post add user surface Zigainer CFX 0 October 2, 2012 09:57
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Assign new variable in CFX Post Ben CFX 1 August 25, 2008 15:59
