Simulation of radial gas turbine, Inlet velocity components
Like Tree4Likes
  • 1 Post By dmaz
  • 1 Post By ghorrocks
  • 2 Post By dmaz
Old   July 4, 2013, 12:38
Default Simulation of radial gas turbine, Inlet velocity components
dmaz is on a distinguished road
I'm trying to simulate a centripetal gas turbine with CFX-Pre. I haven't found any tutorial so I had to try to set the simulation by myself.
I'm analyzing onle the rotor blade, the simulation works but I'm not sure about the results and the setting.
At the Inlet, how have I to set the flow direction? I tried with the cylindrical components. I entered the values of the vector: axial component=0, radial component=0.2233 theta component=0.9748. However the resulting triangle of velocities after the simulation is not the set(in the picture). I'm not able to have a relative velocity entirely radial at the inlet. The rotational velocity is 4666 rad/s.
Where I'm wrong?
Another question, in a rotating domain, is the Velocity Stn the absolute velocity of the flow (c)? And the Velocity is the relative velocity (w)?
Thanks in advance,
Dmaz
masoudmoazzen likes this.
dmaz is offline   Reply With Quote
Old   July 4, 2013, 21:08
If you want to see your initial or boundary conditions then run a simulation where you save a results file at time=0 or iteration=0.
Old   July 10, 2013, 09:04
Thanks for answering me! But I'm not able to solve the proble, I did many attempt...
The complete data of my problem are:
Ptot,inlet=3.02bar
Ttot,inlet=467.6K
Pstat,outlet=1.8bar
Rotation velocity= -4666.67rad/s
The frame type is stationary and the inlet is at a radius coordinate of 0.084m. I don’t succeed in imposing the correct flow direction at the inlet.
The values I’m trying to impose (triangle of velocity A) are:
Absolute velocity c=396m/s
Tangential velocity u=388m/s
Relative velocity w=80m/s
So I set the cylindrical coordinates of the flow direction at inlet as:
r=-0.2019 (w/c)
a=0 no axial direction
t=-0.9795 (u/c)
Is it right? Are they referred to the absolute velocity c right?
However, after the simulation, the triangle of velocities at the inlet is not correct (evaluated as an average of the values at inlet, span 0.5). The calculated values are:
c= 276m/s (wrong)
w=138m/s (wrong)
u=388m=s (right)
And the triangle of velocities is different (triangle of velocity B).
Where I’m wrong? Am I missing something?
I attached also the plot of the vectors of the relative velocity w (Velocity) and the absolute velocity c (Velocity Stn).
karmavatar and masoudmoazzen like this.
Old   July 17, 2013, 06:08
Anyone can help me?
Old   July 17, 2013, 07:25
Can you post your CEL? And an image of the entire flow domain?
Old   July 17, 2013, 09:01
Thanks for answer me!
I post the image of the entire flow domain in the blade to blade (Theta-M') view.
I did my simulation using blade gen-turbogrid-ansysCFX in the Workbench enviroment.
I have exported the CCL file from the cfx-pre, is that the file you mean?
How can I attach it to the message? The forum doesn't accept the file..
Old   July 17, 2013, 17:25
mjgraf is on a distinguished road
set expert parameter
backup file at start = t
Controls whether a backup file is written at the start of every run (that is,
showing the initial values field for the run).
mjgraf is offline   Reply With Quote
Old   July 7, 2014, 04:04
Zhiping Mao
givermzp is on a distinguished road
Hello Dmaz, I got the same problem with you... May I ask how you solved the problem finally?
givermzp is offline   Reply With Quote
Old   May 29, 2015, 01:52
svaezi is on a distinguished road
hi everybody
I have some problem in simulation radial turbine' impeller. when i want to get results from cfd-post the impeller act like a compressor for example the absolute mach number increase from inlet to outlet.what do i have to for this problem????
i set this boundary condition:
PO=1.55 bar
To=1239
Ps=.982
rpm=80000
svaezi is offline   Reply With Quote
Old   May 29, 2015, 09:01
Opaque will become famous soon enough
Have you plot the Rotational Velocity vectors ? is the impeller rotating in the correct direction ?
Bizarre..
Opaque is offline   Reply With Quote
Old   April 20, 2016, 06:24
Default CFX Flow Direction for radial inflow turbine
  #11
Francis Smit
Rad_Turb is on a distinguished road
I am simulating a radial inflow turbine. The velocity triangle at the rotor inlet is known in u,v,w velocity components, however I am clearly making a mistake when converting to cylindrical components.
u = 540.127 m/s
v = 457.7828 m/s
w = 226.5001 m/s
This suggests a relative flow angle of about 33 deg.
a = 0 = no axial direction
r = (w/v) = - 0.494776
t = (u/v) = -1.17987
When reviewing the results only the u velocity component is correct, and the flow angle is much smaller than 33 deg.
If possible could you give some pointers on the situation.
Thanks in advance.
Rad_Turb is offline   Reply With Quote
Old   April 20, 2016, 07:04
Are you looking at the right velocity? velocity or velocity in stationary frame?
Old   April 20, 2016, 07:25
Francis Smit
Looking at the correct velocity, do you mean with regards to the results?
So as a start, do you agree with the method used to convert u,v,w velocity components into cylindrical?
Old   April 20, 2016, 08:33
No. Have a look at https://en.wikipedia.org/wiki/Cylind...rdinate_system
Old   April 20, 2016, 12:53
turbo is on a distinguished road
Where I'm wrong?
Thanks in advance,
Dmaz
Your velocity triangle at radial-inflow turbine rotor is right. The velocity component BCs are calculated from your nozzle exit flow angle you want.
turbo is offline   Reply With Quote
Old   April 20, 2016, 12:56
Ptot,inlet=3.02bar
Ttot,inlet=467.6K
Pstat,outlet=1.8bar
r=-0.2019 (w/c)
t=-0.9795 (u/c)
c= 276m/s (wrong)
w=138m/s (wrong)
u=388m=s (right)
Your results look OK, but your thought that W should be aligned with rotor inlet blade angle, which means zero incidence, is wrong. Generally W should be aligned like what you have to give better efficiency. Study turbomachinery books.
Old   January 28, 2019, 02:25
Default stuck in radial gas turbine inlet velocity condition
  #17
dinesh kumar
dinesh1700 is on a distinguished road
i just started doing simulation of radial gas turbine in ansys cfx, but i am stuck at the inlet velocity condition, as i don't know how to calculate the axial, circumferential and radial velocity.
Initially i did the simulation of both nozzle and turbine and gave the inlet velocity condition based on nozzle angle.
but now i am doing the simulation of only turbine.
dinesh1700 is offline   Reply With Quote
Old   May 19, 2019, 10:45
Default Www
  #18
hector
hectorwerke is on a distinguished road
Anyone can help me?
İ ve same problem with u. But i think when we make a simulation with a volute i hope olur problem May be solved. Because when we add the volute condituons to the whole calculations, rotor inlet flow direction May be calculated auromatically according to volute shape and flow condituons on volute? Thats my opinion
hectorwerke is offline   Reply With Quote
VOF Volume fraction in Velocity inlet aruelle FLUENT 2 May 10, 2024 11:17
How to apply an outlet velocity profile to another inlet? siw FLUENT 4 April 10, 2013 12:19
Gas Turbine combustor inlet boundary condtions jose_rodrig OpenFOAM 3 May 18, 2012 08:13
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 22:18
gas velocity looks weird in vicinity of inlet kaifu OpenFOAM 0 June 21, 2011 06:33
