June 18, 2013, 14:34 |
Pump Cavitation Analysis in ANSYS CFX
CAE Engineer
Rep Power: 13 |
Following is a series of blogs introducing to the basics of the pump cavitation analysis in ANSYS CFX and to automate this process by using CEL (CFX Expression Language) and Perl script.
Pump Cavitation Analysis in CFX (Part I) Pump Cavitation Analysis in CFX (Part II) Pump Cavitation Analysis in CFX (Part III) |
July 1, 2013, 10:54 |
CAE Engineer
Rep Power: 13 |
July 2, 2013, 07:05 |
transient simulation
zhiluguo
Rep Power: 13 |
Hi, I want to simulation the cavitation phenomenon of unsteady in a centrifugal pump by using CFX, can you give me some advice?
thank you! |
July 2, 2013, 07:33 |
#4 | |
CAE Engineer
Rep Power: 13 |
Please follow the tutorials as described in this thread, and do the following: 01: Start with a steady state analysis with cavitation model turned off. 02: Then start another steady state analysis with Cavitation model turned on and initialise this analysis from step 01. 03: Strart the transient analysis with cavitation model turned on and initialise this from the results of step 02. Regards, |
July 3, 2013, 04:37 |
zhiluguo
Rep Power: 13 |
Hi, techCAE
thanks for your reply! I hope to raise another question. As the flow in the centrifugal pump (or other hydraulic) is an unsteady process when in actual operation, can i ignore the second step and in the third step of calculation with the result of the first step as the initial value when start the unsteady cavitation simulation? What's the distinction between the result of this method and yours? I'M looking forward to your reply! regards |
July 3, 2013, 04:38 |
#6 | |
zhiluguo
Rep Power: 13 |
July 3, 2013, 06:37 |
#7 | |
CAE Engineer
Rep Power: 13 |
That could be a good learning exercise for you, (if you are at initial stages of that analysis). Please try both and then look at the difference. |
ansys, cavitation, cfx, impeller, pump |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 05:52 |
Compressible Flow in Ansys CFX | bcheruk | CFX | 15 | July 6, 2017 06:30 |
ANSYS and CFX not talking in two-way FSI? | brashear | CFX | 6 | November 25, 2012 08:13 |
Electronics Enclosure Analysis with CFX | Simulation Engineer | CFX | 1 | April 22, 2009 11:08 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 01:10 |
