How to check the convergence of the CFX solver? |
May 24, 2013, 05:30 |
Candy
Rep Power: 13 |
I would like to know how i can make sure that my solver is definitely converging. In other words, what should i check in the out. file ? (how should the residual values be?) Knowing that i am using: -steady state solution -CFX stand alone mode -High resolution scheme PS: The FAQ of CFD online did not help me at all! Thank you, |
May 24, 2013, 07:13 |
Rep Power: 144 |
There is a section in the CFX documentation on obtaining convergence.
May 24, 2013, 07:24 |
Candy
Rep Power: 13 |
What is your own method?
May 24, 2013, 07:26 |
Rep Power: 144 |
Residuals always, imbalances sometimes, other important parameters (lift, drag, pressure loss) sometimes.
May 24, 2013, 07:31 |
Candy
Rep Power: 13 |
would you please explain in details what you check exactly in the residuals?
May 24, 2013, 07:40 |
Rep Power: 144 |
Have you read the section on obtaining convergence? I hope you are not expecting me to re-type the entire chapter of the documentation.
May 24, 2013, 07:48 |
Candy
Rep Power: 13 |
Of course not!
Ok! and thank you very much for your help |
May 24, 2013, 07:57 |
Stuart
Rep Power: 26 |
Another useful resource:
http://www.computationalfluiddynamic...pendent-study/ In fact, it is worth reading all of the LEAP Australia blogs as there is lots of useful information - which would save lots of people having to make forum topics. |
May 24, 2013, 08:00 |
#9 |
Candy
Rep Power: 13 |
Thanks a lot Stuart
May 30, 2013, 06:46 |
#10 |
David
Hi, im new to OpenFoam.
I simulated a cyclon. The results in paraview are looking good, compered to other cylon simulations with cfd. Now I want to do a Convergence Study with the pressure drop, but I dont know how i can implement to OpenFoam to calculate the pressure drop. In the tutorial that i use, there is a folder created "forces" in witch there is a text data "forceCoeffs.dat". There is the cd-Value saved. I can export these data to excel and do the Convergence Study with the cd-Value, but i want to do it with the Pressure drop. But the Pressure drop is not calulated. Can someone explain how to do it. I read through "computationalfluiddynamics.com.au/convergence-and-mesh-independent-study/" but it is mentioned that you can do it with the pressure drop, but it is not discribed how. |
May 30, 2013, 06:57 |
#11 |
Rep Power: 144 |
This is the CFX forum, try the openfoam forum.
June 17, 2024, 08:18 |
#12 |
Ali
Rep Power: 10 |
June 17, 2024, 11:17 |
#13 |
Gert-Jan
Rep Power: 28 |
June 17, 2024, 19:55 |
#14 |
Rep Power: 144 |
CFX documentation references for obtaining convergence:
* CFX-Solver Modeling Guide, Ch 16 * CFX Reference Guide, all the best practices guides
Convergence | Centurion2011 | FLUENT | 48 | June 15, 2022 00:29 |
Fluent Adjoint Solver Convergence Issue? | ex10148 | FLUENT | 2 | July 25, 2016 15:41 |
force convergence problems in CFX 6DOF rigid body solver | ajay_ks | CFX | 8 | March 25, 2013 05:02 |
Small time step and CFX solver crashing | Vanessa | CFX | 2 | June 21, 2006 10:18 |
Convergence with coupled implicit solver | Henrik Ström | FLUENT | 1 | October 29, 2005 04:57 |
