May 10, 2013, 13:24 |
Rotating Boundary, Wheels
Rep Power: 14 |
I tried to simulate a regid body with a diffusor and rotating wheels. But it seems like it dont work.
Without wheels my simulation is covergent after some iterations but i dont know how to setup the wheels. I meshed it like in this picture : Then I define the wheel as a no slip wall with a rotating velocity. But i get an error that i have a significant normal component at one or more faces and that the angle between the velocity and the surface is almost 90 degrees. Whats wrong? The ground is also moving. Should i define the wheels as complete new domain and let the domain rotate? And guidance would be great! Ps: I use CFX Pre and ICEM |
May 10, 2013, 14:44 |
Erik
Rep Power: 23 |
Does global X go right through the center of all four wheels? No, It can't, so my guess is you will have to define the proper axis of rotation.
May 10, 2013, 15:03 |
Erik
Rep Power: 23 |
May 10, 2013, 15:10 |
In reality they are somehow flat at the intersection with road, but not as modeled in pics in above post. They look like a extruded part. Correct method would be to intersect wheels with road and give corresponding velocity to road (convert circular to rectilinear)
May 10, 2013, 16:17 |
Rep Power: 14 |
I heard that it wont work if i mesh the tires tangential to the road. Somebody told me that it would produce a "singularity" and wont work.
I could just model the tires to the road without the vertical transition and specify the "wheel wall" as wall boundary with a rotating velocity (with right axes )and the "ground" as moving wall? Would this work? I'm thankful for your help :-) |
May 10, 2013, 16:20 |
#7 | |
Tangential boundary will create problems for meshing or solver? If meshing, I can show you how to handle. But solver should not have any problem.
May 10, 2013, 17:39 |
Rep Power: 14 |
I could also do it in fluent if its easier to setup.
I still wonder if i should define it as wall in one fluiddomain or should i do three bodys- For each wheel a solid and the fluid domain? I think the solution with one domain would suit better, but if the wheel is tangential to the ground i create 3 domains? |
May 11, 2013, 00:38 |
#9 |
Rep Power: 144 |
Do not model rotating tyres with a rotating frame of reference. This can all be modelled in the single stationary frame of reference with a tangential velocity (which happens to rotate).
Also, the funny little bits at the bottom of the tyres to eliminate the cusp point will make it MUCH easier to mesh this. If you are not interested in little details like this you will find this assists immensely. |
May 11, 2013, 04:54 |
#11 |
Rep Power: 14 |
May 11, 2013, 07:44 |
#13 |
Rep Power: 144 |
Just to check - are you doing this simulation with a rotation frame of reference or with just rotating boundary conditions?
Noe that if you are doing it with rotating BC then as the effective frame of reference for the simulation is translating with the vehicle, then the rotation axis for the wheel is through its centre, with the road surface having a tangential velocity backwards. |
May 11, 2013, 12:30 |
#14 |
You may find it interesting : Post # 14 and image no 3
http://www.cfd-online.com/Forums/ans...rmula-one.html For boundary conditions, now it is clear that you have to specify road a tangential velocity = omega * R (radius of wheel) in back ward direction. |
May 14, 2013, 05:39 |
#15 |
Rep Power: 14 |
It is my "backup" plan to mesh it tangential.
But i will first try it with the bits. But i think i cant find proper points to define my axis of rotation Front tyre: Start: 1200 | 515.392105 | -175 Oriantation : 800 | 515.392105 | -175 Back tyre : Start : 1 100 | -656,65112 | -175 Oriantation : 800 | -656,65112 | -175 I attached my geometry, could someone who is better than me in icem(i think almost everybody) check the geometry for the proper middle of the tyres? That would help me alot. http://dfiles.eu/files/2awsgnn1y If i mesh it like this do i have to calculate the rotating speed with 175 mm or with 160 mm? Last edited by ChrisR; May 14, 2013 at 06:33. |
May 14, 2013, 09:02 |
#16 |
Rep Power: 144 |
If you are trying to get the rotational speed of the tyres correct based on the sag, then the correct answer is in between these two values. But I would not worry about minor details like this, it is unlikely that this small difference in the rotational velocity makes a difference anyway. If you do not believe me run them both and compare them - I bet they are the same.
May 14, 2013, 09:52 |
#17 |
Rep Power: 14 |
Then my axes are probably false?
Vehicle Simulation with Rotating Wheels | Natalia Castro Naranjo | FLUENT | 1 | May 14, 2012 11:39 |
how to set rotating boundary? | conan | FLUENT | 2 | April 6, 2012 01:22 |
how to move a rotating boundary | zyf | FLUENT | 1 | December 3, 2007 03:49 |
Rotating boundary | eros | CFX | 5 | May 16, 2007 19:09 |
Solver error message!!! | IoSa | CFX | 1 | September 14, 2006 05:48 |
