April 25, 2013, 22:09 |
Question about permeability setting
Meimei Wang
Rep Power: 16 |
We could set up streamwise permeability and transverse permeability at CFX. That means we will have a streamwise permeability at one direction and a transverse permeability at the other two directions (The other two directions have the same permeability). But I'd like to have three different permeability at the three directions. May I ask how to set up three different permeability at the three directions in CFX?
Best regards, Meimei |
April 26, 2013, 10:08 |
Stuart
Rep Power: 26 |
I've not tried a simulation to check the results but just did a quick set-up.
How about instead of using a porous domain you use 3 subdomains for the porous region. In each subdomain you set the streamwise direction to be 1 for a particular permeability value and then set no traverse loss, see the images with random values. That way you can input the 3 permeability values for each direction. I'd be interest to know if this works. |
question regarding the codes for setting inlet flow | Alicelin | OpenFOAM Pre-Processing | 4 | November 11, 2009 04:04 |
LiftDrag utility from v12 to v141 | cfdphil | OpenFOAM Running, Solving & CFD | 2 | December 5, 2007 06:49 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 05:37 |
Ultra high temperature? | bk | Siemens | 2 | July 19, 2005 01:01 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
