Setting Domain for two parallel fans
Like Tree2Likes
  • 1 Post By ghorrocks
Old   April 10, 2013, 03:27
Default Setting Domain for two parallel fans
Bahar
bahar is on a distinguished road
Hi everybody,
I hope you are all well.
I am modeling two parallel fans using CFX-Pre. I have created mesh for one fan and copied it where the second fan is placed. The next step which is defining Domain for them has faced a problem.
I used below instruction after inserting both meshes:
Insert --> Domain --> Selecting related main passage and setting axis using two points.
Unfortunately it returns below error:
"In Analysis 'Flow Analysis 1': The same location has been specified for more than one domain." and cannot create both domains.
What should I do?
Any suggestion is very welcomed.
Regards,
Bahar
bahar is offline   Reply With Quote
Old   April 10, 2013, 08:28
As the error message says, it simply means a mesh domain is in more than one domain. Check which meshes are allocated to your domains and you will find a duplicate in there somewhere.
Old   April 10, 2013, 10:16
Bahar
Dear Glenn,
Thank you for your fast reply.
Sorry for my basic questions. I am new to CFX.
As you said there was a duplicate in domain. Now, that error has disappeared!
But there are some problematic errors related to interfaces! Actually the interfaces which has been defined correctly and as it could be seen in below picture, although it is needed to define two inlet and two outlet; there is an inlet and outlet!
Regards,
Bahar
Old   April 10, 2013, 22:06
Your image is not readable.
But the error looks the same, just on the boundaries this time. Check for duplicate boundary faces between boundary conditions.
bahar likes this.
Old   April 11, 2013, 02:34
Bahar
Thank you dear Glenn for your fast reply.
As I said I am new to CFX and don't know exactly how to define the BC around a fan. Is there any good tutorial for it?
Thank you in advance.
Regards,
Bahar
Old   April 11, 2013, 06:50
The tutorials which come with CFX are the best place for the basics.
You have multiple ways of selecting regions for boundaries and domains. You can select them by clicking on them in the graphics window, you can select them by named group, you can select them by mesh primitive or you can edit the CCL directly with a text editor. Try them all out and get a feel for what is good for what purpose.
bahar likes this.
Old   April 11, 2013, 06:58
Bahar
Thank you dear Glenn.
I will try them and report the result soon.
Regards,
Bahar
Old   April 17, 2013, 11:21
Bahar
Dear Glenn,
I hope you are well.
I defined BC for both fans and the errors came out. It solved the Domain, but there seems to be a problem somewhere...
As it's showed in below picture,there is basic difference between the geometry of two fans although there were similar.(I created second by copying mesh of first)
What should I do?
Best Regards,
Bahar
Old   April 17, 2013, 19:47
Showing what the error is might help....
Old   April 18, 2013, 04:20
Bahar
Hi dear Glenn
Thank you for your attention.
It don't show any error for it. My problem is that the geometries should be the same because I transferred first mesh in x-direction to create second mesh and then loaded the first mesh. So I expect that the geometries to be exactly the same as each other. But they have basic differences as showed!
I am so confused about it! Once I tried to transfer the geometry in TurboGrid and this problem appeared, so as a friend advised I transferred the mesh in CFX-Pre.
Best Regards,
Bahar
Old   April 18, 2013, 07:31
What are you doing this in? CFX-Pre? Turbogrid?
Old   April 18, 2013, 09:30
Bahar
This pictures is related to doing that in CFX-Pre.
Is there more appropriate way?
Best Regards,
Bahar
Old   April 18, 2013, 19:50
Doesn't this mean you just transformed part of the mesh, not the whole mesh? Then right click on the whole mesh and transform it.
Old   April 20, 2013, 02:09
Bahar
Hi dear Glenn,
I selected the main domain to transform. Isn't enough?
Best Regards,
Bahar
Domain and boundary axis are not parallel romed CFX 1 September 24, 2016 11:42
Numerical errors in nested domain with pre-calculated boundary values Arnoldinho OpenFOAM Running, Solving & CFD 3 April 4, 2012 11:31
Error (2 isolated fluid regions) with an englobing domain syens CFX 2 January 12, 2012 11:55
basic rules for partition domain for parallel run phsieh2005 Main CFD Forum 19 September 18, 2006 10:34
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
