Parameter Design point update Workbench 14
Like Tree2Likes
  • 1 Post By Sixkillers
  • 1 Post By panks
Old   February 15, 2013, 09:16
Default Parameter Design point update Workbench 14
Pradeep
snpradeep is on a distinguished road
Hi All,
I wanted to simulate few cases using parameters in Workbench 14. When i create the design points and say update all design point workbench 14 dosen't seem to work. Has anyone faced similar problem..?? Is there any other way to make it work??
It will be of great help from you..
Regards,
Pradeep
snpradeep is offline   Reply With Quote
Old   February 16, 2013, 15:35
Erik
evcelica is on a distinguished road
Do you have input and output parameters entered? Once you say update all design point it should start working, look on the bottom left of the screen and it will show you the status, sometimes you think its not working when it really is.
evcelica is offline   Reply With Quote
Old   February 18, 2013, 05:01
Pradeep
Hello Evcelica,
I have just input parameters..Funniest thing is it works in Ansys 12.1 but not in Ansys 14.I montitored at the bottom of ANSYS window in progress window. I was puzzled when I saw this. It says it is updating but it dosen't load the solver. Is it bug in Ansys 14 or I may have to reinstall Ansys 14. But its ok I am using Ansys 12.1 as it works on it.
Old   February 3, 2014, 15:51
Daniel Jochelavicius
Daniel J is on a distinguished road
Send a message via Skype™ to Daniel J
My problem on Ansys v14 is that it creates one workbench project for each design point. That create a real mess on the workbench files...
On the earlier versions it doesn't happens. It's like that only for me?
Daniel J is offline   Reply With Quote
Old   February 4, 2014, 05:06
Pradeep
Hi Daniel,
Ansys works in similar fashion..It creates folders inside folders..It just consumes lot of space..If you use initial value specification file.With every design point it also copies it along with it..It is much better if one works without workbench using batch files..But only problem is you have to manually create each case file..Which is also time consuming..But it looks more organized..
Regards,
Pradeep
Old   February 4, 2014, 07:53
Hello snpradeep,
If I understood what you said clearly, thats what I'm doing. I setup my case on Fluent, export a .cas file and then run each designpoint separately.
That solves my problem. But I need to run each case separately, so I can't let the computer work continuously for days, then I lost a lot of time...
If anyone knows how to fix it I'll be greatefull!
Best regards,
Daniel
Old   February 4, 2014, 08:19
Sixkillers is on a distinguished road
Hi. You have to define at least one output parameter in order to run a parameter study. It can be even a constant.
Also don't forget to toggle on Exported in each design point, so your files will be preserved:
Cheers
Daniel J likes this.
Sixkillers is offline   Reply With Quote
Old   February 5, 2014, 03:39
Pradeep
Hi Daniel.
Have you tried speaking to Ansys Technical support. May be they can fix your problem.
Regards,
Pradeep
Old   July 22, 2017, 23:23
Post Same Issue, Hope you can help me
jjfm20 is on a distinguished road
Hello guys,
I'm having exactly the same issue with workbench, I tried to update a list of design points and it goes to the process and starts to solve it but eventually it's unable to close the design point and pass to the next, I know it solves the point because I'm checking the CPU performance and it's 100% as set previously for each simulation, but the progress bar shows up it's still solving when actually the performance goes down to 5%.
Hope you can help me. I have to do like 150 design points (With the same mesh), they run ok separately but it is exhausting because I have to retrieve and treat a lot of parameters before I can use them and I'm kinda against time.
Regards.
jjfm20 is offline   Reply With Quote
Old   July 23, 2017, 04:18
The CPU issue sounds like you are running out of memory. The extra memory for the parametric run could be too much.
Old   July 23, 2017, 10:50
Hello ghorrocks,
Thanks for your reply, I did check the memory usage and is always below 50%. Also the design points should run one by one, so maybe if you can specify a little more the memory issue I'll be so glad.
Regards.
Sent from my LG-K430 using CFD Online Forum mobile app
Old   July 23, 2017, 19:35
If the total memory useage is under 50% while you are doing this then that suggests the memory is OK and something else is causing the issue. Another issue the parameteric run requires is it has to calculate the parameters which you are parametrising. If these parameters are complex to calculate that might take a while.
Old   July 27, 2017, 00:19
Post
  #13
I apologize for the late answer, still I can't find the propper solution, it's a sad stuff.
Also, I recently get this error "An error occurred in fluent when disabling writing of transcript file" but don't know how to proceed.
Regards.
Old   February 6, 2018, 08:32
bend is on a distinguished road
hi,
i have a very similar issue. Is there any new opinions on this?
BR, B.
bend is offline   Reply With Quote
Old   February 6, 2018, 17:45
On what issue? Updating design points, CPU utilisation problems or something else? This thread covers a few topics.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   August 29, 2020, 14:11
Pankaj
panks is on a distinguished road
I'm trying to run a simple fluid analysis with a series of different parameter inputs. When I try to update a Design Point from the project schematic, I get "Update failed for Solution component in Fluid Flow (Fluent) for Design Point 0. Update Solution Failed." From that point I can either open up Solution and run it manually abd everything goes fine, or I can open Setup (and do nothing in Setup at all) and update again from workbench and everything works fine. I'm new to Workbench so I'm probably just doing something dumb, but I can't figure out what.
elochana likes this.
panks is offline   Reply With Quote
Old   December 7, 2020, 15:49
elochana is on a distinguished road
Did you find a solution to this. I'm having the exact problem right now, at this hour. If anyone can help, would be grateful.
Thanks
elochana is offline   Reply With Quote
cfx, parameter, workbench 14
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 10:23
Using Workbench, CFX-Pre doesn't update mesh from upstream data Shawn_A CFX 2 November 25, 2012 14:06
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
Track a flow parameter on a point Astozzia FLUENT 0 May 24, 2006 18:09
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
