Import to Bladegen
Like Tree1Likes
  • 1 Post By Ludvik
Old   January 29, 2013, 15:50
Arrow Import to Bladegen
Asak
hasbi is on a distinguished road
Hello all my friends
I want to create wind turbine blade in bladegen, We know that it has twist in its length and contain many type of airfoils (in my problem 10 sections)
I have two request from you
please tell me
A)Is it possible to import the coordinate of airfoil in .txt format and set it for any section?(I try for this but it gives me error)
B)Is it possible to create blade with twist?
THANK YOU ALL
hasbi is offline   Reply With Quote
Old   January 30, 2013, 10:58
Ludvik is on a distinguished road
- In BladeGen Data Import Wizard you may load *.txt files (sections) and mark separated group of point as a unique blade layers.
- Blades twist is in BladeGen possible.
Ludvik is offline   Reply With Quote
Old   January 31, 2013, 02:15
Asak
Thanks
I can't do import *.txt . Please give me a brief help for do it.
Old   January 31, 2013, 05:07
1. Open BG GUI.
2. File > New > Data Import Wizard
3. in 2nd step "Gather Geometry" add *.txt files.
4. Points format *.txt files (for each profiles) is:
(1.00 0.00 1.00)
(1.20 0.10 1.50)
(1.20 0.40 2.50)
Old   February 1, 2013, 06:02
Default error
Asak
Thank you Ludvik Lanicek for your attention
I do it but in step 2 I import an airfoil and it want me Hub and shroud
this picture is its picture
http://www.mediafire.com/view/?bwwypbdckdt7la4
And for import separately three airfoil ,it gives me error too!
http://www.mediafire.com/?smlt1a7nbh516i9
I write 1 , 2 ,3 for easy to help me
Please help me
Thank you
Old   February 1, 2013, 06:25
Hub is surface of pylon.
Shroud is surface of revolution between static and rotating domains in CFD simulation.
Old   February 1, 2013, 07:53
Asak
Thank you for your quick answer
but I don't know have to select them
please tell me which point or surface must be selected in this picture?
http://www.mediafire.com/view/?cesgsivga159u52
Thank you
Old   February 1, 2013, 08:27
Hub and Shroud represent separated (new) curves.
http://www.mediafire.com/view/?awrb3c5cc1qb43u
hasbi likes this.
Old   February 1, 2013, 09:45
Asak
For wind turbine I select shroud ,green line and hub blue line (in picture)
http://www.mediafire.com/?8zfhl35aj3vhbm2
Is it true ?
what's standard distance between end of blade and shroud ?
Thank you my friend
Old   February 1, 2013, 10:32
Asak
I select the hub and shroud like this
http://www.mediafire.com/?nx3iqgd4d2zaz2j
Old   February 1, 2013, 13:04
Default ؟؟؟
  #11
Asak
I give the hub and shroud as above picture!!!!!
If I give (1) in below picture, it gives me error (8) (its procedure in picture)
http://www.mediafire.com/?1lh135adtkxr34z
If I select (2) in picture , result is below shape!!!!!!!
http://www.mediafire.com/?89ec47xz03upk65
I think my hub and shroud is incorrect!
help me
thanks for your patience
Old   February 8, 2014, 13:40
Sathyanarayanan Nagasundaram
nsathya.mech is on a distinguished road
Hello Mr. Hasbi,
I would like to know how you selected the meridional curve.
nsathya.mech is offline   Reply With Quote
Old   November 9, 2014, 05:34
Unhappy I worry
  #13
saeed_karami, s_karami_mut_ac@dr.com
saeed_karami is on a distinguished road
Originally Posted by nsathya.mech View Post
Hello Mr. Hasbi,
Hi nsathya, I want to make BladeGene rotor 67 in the coordinates of the point I'm level 15, but I do not know how to enter please tell me?
saeed.karami@chmail.ir
saeed_karami is offline   Reply With Quote
Old   November 9, 2014, 05:42
Unhappy rotor 67
  #14
im worry!!!
How import cordinate nasa rotor 67 to bladegene ansys?
bladegen data import issues sanandtv CFX 8 April 2, 2016 06:16
I developed an FEM toolkit in Java: FuturEye nkliuyueming Main CFD Forum 7 January 29, 2016 14:28
BladeGen: problem with geometry import famarcfd ANSYS 0 December 10, 2010 03:12
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
import airfoil in Bladegen SERGIO CFX 3 August 2, 2007 10:16
