November 8, 2012, 04:15 |
Enthalpy of mixing(heat of mixing)
George Sladkovsky
Rep Power: 14 |
Hello!
Can someone tell me is Ansys CFX takes into account the enthalpy of mixing(heat of mixing) when two different fluids are mixed in the process of calculating? If yes, in witch equation? Thank you very much for your attention. |
November 8, 2012, 07:09 |
Erik
Rep Power: 23 |
I'm guessing you mean some sort of chemical reaction where the mixing process produces heat energy? CFX will not just do this by default. You would have to set up the chemical reaction process to make this happen.
November 8, 2012, 07:50 |
#3 | |
George Sladkovsky
Rep Power: 14 |
Thank you for your reply evcelica.
I mean, this enthalpy of mixing: Quote:
Thank you for your attention. |
November 9, 2012, 20:57 |
Erik
Rep Power: 23 |
I think I understand this "enthalpy of mixing" but I'm not a chemist. Is it like when you mix ammonia and water, and it creates heat and the temperature will rise as the two mix?
If so, then no, CFX will not do this by default, it will just interpolate the material properties between the two; and the temperature would just be an interpolation of the two temperatures as well. If you want to simulate the "enthalpy of mixing" then you will have to set this up in CFX as a reaction process. |
November 10, 2012, 03:55 |
George Sladkovsky
Rep Power: 14 |
As i remember the ammonia and water reacts when mixing forming ammonium hydroxide:
(NH3 + H20 -> NH4OH) and this reaction is exothermic ideed. But what happens when two non-reactive fluids mix? I suppose, if you choose "Ideal mixture" you just get interpolation of enthalpies with no additional enthalpy change. Am i right? |
November 10, 2012, 19:26 |
Erik
Rep Power: 23 |
Yes I would believe that is correct. Why would CFX ever just add or subtract anything else to the enthalpy? The solver theory guide would have more information on the mixing models.
November 11, 2012, 05:35 |
George Sladkovsky
Rep Power: 14 |
Thank you very much for your answers! It helped me a lot.
Sensible Enthalpy vs. Total enthalpy | Sethi | OpenFOAM Programming & Development | 3 | March 23, 2017 22:48 |
Problem with Mixing plane | Mitpostdoc | FLUENT | 0 | July 26, 2011 15:31 |
Meshing a Mixing Plane using ICEM | Will Anderson | FLUENT | 0 | November 6, 2010 18:08 |
turbine efficiencies, conservation rules across mixing planes | Jonathan | FLUENT | 0 | October 4, 2010 10:04 |
Mixing plane geometry definition | Hbet | FLUENT | 0 | January 18, 2002 08:16 |
