"if" command in CFX-13 is not really an "if" command!!!!
Like Tree6Likes
  • 1 Post By mohammad
  • 4 Post By cdegroot
  • 1 Post By ghorrocks
Old   October 16, 2012, 08:16
Question "if" command in CFX-13 is not really an "if" command!!!!
mohammad
mohammad is on a distinguished road
Dear All,
I am trying to make a conditional expression with "if" command in CFX-13.
Amazingly, the if command is not true...
for example, create this expression and see the results!!!
-if (a>5,10,loge(5-a))
if we see the results for any a>5 (e.g. "a=6") the results must be 10
However, the CFX-post tried to calculate the value of "loge(5-a)" which will be an mathematical error.
Seemningly, before applying the if command, the CFX-POST calculated the consequences .....
Any Idea or Alternative solution!!!???
Regards,
Lemanes likes this.
mohammad is offline   Reply With Quote
Old   October 16, 2012, 10:45
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
This is answered in the CFX Reference Guide, section 13.2.2.
CEL supports the conditional if statement using the following syntax:
if( cond_expr, true_expr, false_expr )
where:
cond_expr: is the logical expression used as the conditional test
true_expr: is the mathematical expression used to determine the result if the conditional test is true.
false_expr : is the mathematical expression used to determine the result if the conditional test is false.
Note:**The expressions true_expr and false_expr are always evaluated independent of whether the evaluation of cond_expr is true or false. As a consequence, a conditional statement cannot be used to avoid division by zero as in if( x>0, 1/x, 1.0). In this case, when x=0.0, a division by zero will still occur because the expression 1/x is evaluated independent of whether x>0 is satisfied or not.
mvoss, Luis Lei, mrkmrk and 1 others like this.
cdegroot is offline   Reply With Quote
Old   September 25, 2013, 09:32
Default alternative here?
Lingyun Lei
Luis Lei is on a distinguished road
thank you very much for your infos, which is quite helpful to me. But, what can I do, if i do need the ,,real'' conditional statement? Is there a alternative maybe?
best wishes
where:
Luis Lei is offline   Reply With Quote
Old   September 25, 2013, 19:39
If you are asking how to get around the caveat Chris mentions (that both true and false expression must evaluate or you get an error) - then the best way around this is to use a fortran user routine where you can use if/then/else statements. This is reasonably easy to do, use a user CEL expression linked to the fortran routine. See the documentation for details, it has examples of how to do it.
Luis Lei likes this.
Old   September 26, 2013, 08:10
Lingyun Lei
Yep, thanks very much, i've found the documents needed and i'll do it.
Different result in CFX and fluent for mass trans.? is segregated better? ftab CFX 7 September 27, 2012 08:57
CFX - Solidworks Flow, Impeller comparison aerospace_guy_ CFX 8 March 20, 2012 23:06
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
