Y plus for various turbulence models
Like Tree23Likes
  • 18 Post By ghorrocks
  • 3 Post By ghorrocks
  • 2 Post By cfdmms
Old   September 16, 2012, 14:58
Default Y plus for various turbulence models
TA Ramanathan
taram is on a distinguished road
Dear all,
I am working on the study of wall treatment for different turbulence models (fluid domain as cyclone separator). This simulation is carrying out flow simulation alone for better understanding. In the above mentioned work, I need to know the effective range of y plus for various turbulence models such as k-epsilon, k-omega, SST and RSM etc. I have searched but I could not get material which gives elaborated details. So, I wish to know the range of y plus has to be used or better if you give me link to come across the same.
Thanks in advance.
taram is offline   Reply With Quote
Old   September 16, 2012, 19:44
SST can handle any y+.
k-e should be >11
k-omega should be <1
RSM should be >11 if using wall functions or anything if automatic.
But the final decision on wall mesh resolution should always be determined by a sensitivity study in your case.
Old   September 17, 2012, 07:28
TA Ramanathan
Hi Glenn,
Thank you for valuable details. I will check on each turbulence models and do for sensitivity study.
Old   September 18, 2012, 03:48
Hamed Abdul Majeed
hamed.majeed is on a distinguished road
Does these limits change:
1. If flow is internal or external.
2. Using wall functions
Thank you
Regards
Hamed
hamed.majeed is offline   Reply With Quote
Old   September 18, 2012, 20:41
1. No.
2. If you use wall functions then you need y+>11.
This is all basic application of the wall boundary condition theory. If you read up about the wall boundary condition and understand it then the reason for these answers become obvious.
Old   December 10, 2013, 02:37
MMS
cfdmms is on a distinguished road
k-e should be >11
If you kindly explain why these values of yplus is vary over different turbulence models? and what about LES?
Thanks.
lm0x and ABgabriel13 like this.
cfdmms is offline   Reply With Quote
Old   December 10, 2013, 04:13
Question
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
k-e should be >11
Are you sure that k-e should be >11? Does CFX have low reynolds number K-e model like Fluent which likes to have Y+ < 0.2? I thought these two software are almost same at wall treatment for different turbulence modeling.
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   December 16, 2013, 01:11
Antanas is on a distinguished road
As far as I understand CFX uses scalable wall functions with k-e model. If mesh is too fine near the wall then CFX ignores this region by "mathematically" placing first mesh node at Y+ ~ 11.
Antanas is offline   Reply With Quote
Old   December 16, 2013, 12:44
OJ
oj.bulmer will become famous soon enough
In original k-e model, the definition of turbulent lengthscales and eddy viscosity has eps at the denominator. Due to rapid changes to k and eps as we approach wall, and hence in the values of lengthscales and eddy viscosity within the viscous layer, there are stability issues (along with divide by zero etc) hence wall functions are not optional.
But the low Re k-eps models in FLUENT (Launder-Sharma, Yang-Shih etc) all use damping functions and redefined values of eps to regularise the extremities in k and eps near wall and hence integration to the wall is possible with Y+ values less than 1 etc.
There are w based models both in CFX and FLUENT which are which are generally favoured.
oj.bulmer is offline   Reply With Quote
y plus
different zones, different turbulence models gmwsy FLUENT 5 June 17, 2020 16:42
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 11:26
LES & DES turbulence models Seva Reehal CFX 5 October 18, 2009 09:44
Tutorial 21: Turbulence models spatialtime CFX 4 April 24, 2009 06:25
Turbulence models for GCV method dosen't work! Sima Baheri Phoenics 0 January 6, 2007 05:08
