set up mixing plane between impeller and vaned diffuser |
August 22, 2012, 03:58 |
layth
Rep Power: 15 |
Hello dears all,
Please Could any one can help me regarding how to make proper set up for the frame mixing plane between the centrifugal compressor impeller and vaned diffuser by using ansys CFX. I had done the ansys tutorial,but I didn't find the steps about that. I did every things for setting up I still can not make run for my case. I will be very happy and grateful if any one can help me Thanks in advance |
August 24, 2012, 08:18 |
DB
Rep Power: 15 |
Create a domain interface between the impeller and volute and use the stage approach, it is a mixing plane approach. Is this what you wanted ?
-D.B |
set up the boundary mixing plane between impeller and vaned diffuser | layth | CFX | 1 | August 19, 2012 20:17 |
