cfx post- two phase flow- particle size distribution
Like Tree1Likes
  • 1 Post By ghorrocks
Old   July 12, 2012, 09:19
Default cfx post- two phase flow- particle size distribution
hari
hari139 is on a distinguished road
hello all,
i am doing two phase flow steady state simulation (spray drying process) in cfx. my questions are
1) How to see the data of each single particle like moisture content , residence time ,velocity, temperature..etc..in cfx post
2)and also i would like to plot the size distribution of particles after drying process in cfx post..how can i do that..?
please help me...if any one knows
thanks
hari
hari139 is offline   Reply With Quote
Old   July 12, 2012, 19:47
Have a look at the CFX tutorials. There is some which do particle tracking so they will give some ideas on how to post process them.
Old   July 13, 2012, 09:32
hari
thanks for your reply Glenn
actually i am doing simulation in cfx with a 9 degree section of my full geometry.
1)firstly i have full doubt about that how to check whether we got proper results after simulation ?
2) is it necessary to perform grid independence test..? because i have done some basic steady state simulation with 25000, 45000, 65000,90000 elements mesh..i have compared the velocity profile at particular location(line in radial direction) which shows agree with some % of error..but when i used fine mesh its not able to get converged and some times it displaying wall has been placed at outlet boundary
so my question is that should i go for fine mesh or any coarser mesh also fine to perform my simulation..how to choose mesh size?
3) what it means if domain imbalance comes as negative ?
and also can u please suggest me if possible the tutorial that which has covered that particle tracking in post process...?
Old   July 14, 2012, 06:23
1. This series of FAQs concentrates on inaccuracies, but the discussion will be of use: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
2. It is common to have problems with convergence in finer meshes. If you have already shown that your answer is good within an acceptable accuracy then you should be OK.
3. Negative/positive just means there is a +/- mass/momentum/heat imbalance across the domain.
ali30369 likes this.
cfx post sizedistribution
Particle deposition on circular cylinder in turbulent flow Julian K. CFX 1 October 3, 2011 18:51
Mesh size for particulate flow simulations Shahri Main CFD Forum 0 March 24, 2009 18:40
DPM particle size distribution in Fluent Pete FLUENT 5 July 7, 2008 13:22
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 11:44
low speed compressible two phase flow?? cat CFX 0 November 15, 2005 08:59
