Troubleshooting ''ERROR #001100247 has occurred in subroutine''
Like Tree1Likes
  • 1 Post By Gweher
Old   July 2, 2012, 03:07
Default Troubleshooting ''ERROR #001100247 has occurred in subroutine''
Francis
Francis is on a distinguished road
Hi everyone
Can anyone help troubleshooting this error? I'm using Ansys 13.0. The mesh statistics are around 550,000 nodes. The CFX solver works well for mesh below 550,000 nodes but not above 550,000 nodes. Below are the errors that came out. The error message mentions a licence for all models is missing. Appreciate if anyone can help solving this problem. Thanks.
Unable to check out 1 licenses: No license for ANSYS CFX Solver (All Models) could be found.
ERROR #001100247 has occurred in subroutine . |
| Message: |
| The solver is unable to continue because of licensing problems. |
| A license for the following capability level could not be checked |
| out: |
| Basic Capability Solver |
| Please carefully examine the error message output above and check |
| that: |
| 1) The license server is specified correctly and is running. |
| 2) An appropriate license is available for checking out. |
| These problems can be checked using the ANSYS Client ANSLIC_ADMIN |
| utility. For further troubleshooting information please consult |
| ANSYS, Inc. Licensing Guide. |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
This run of the ANSYS CFX Solver has finished. ''
Francis is offline   Reply With Quote
Old   July 2, 2012, 07:35
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Isn't it obvious, there is something wrong with the license... If you use the search tool you would have found topics related to your error
Originally Posted by Glenn Horrocks
;85811
Check the license manager to see if the solver is checked out. Sometimes the licenses do not check themselves back in again properly. Check the license manager log file, that may also help.
99% of licensing problems like this are fixed by shutting the the license server machine down and starting up again. A bit brutal and it can be done far more elegantly if you know how to drive license servers but it works and is simple.
saravenu likes this.
Gweher is offline   Reply With Quote
Old   March 31, 2014, 23:32
Default I get this problem. Yesterday it was working fine with same mesh and same settings.
sanam pudasaini
pudasainee is on a distinguished road
| Message: |
| out: |
| ANSYS CFX Solver (> 512K Nodes) + Parallel |
| that: |
pudasainee is offline   Reply With Quote
Old   April 1, 2014, 03:26
Lance
Lance is on a distinguished road
As post #2 says, the error is obvious. You could not check out a license for a mesh with >512k nodes. Either they were already in use by other users, or something is wrong in your license setup.
Lance is offline   Reply With Quote
error #001100247
ERROR #001100279 has occurred in subroutine ErrAction. wangy1767 CFX 36 July 25, 2020 07:09
ERROR #001100279 has occurred in subroutine ErrAction alinik Main CFD Forum 0 July 3, 2010 09:11
ERROR #001100279 has occurred in subroutine ErrAction. P9408 CFX 1 August 19, 2009 08:56
ERROR #001100279 has occurred in subroutine ErrAct Mohamed Musthafa CFX 0 September 29, 2005 09:41
ERROR #001100279 has occurred in subroutine ErrAct Carl CFX 2 July 16, 2005 15:39
