Home > Forums > General Forums > CFD Freelancers
Average Nusselt number or heat transfer coefficient to compare better heat transfer?
Like Tree1Likes
  • 1 Post By evcelica
Old   September 8, 2019, 17:15
Default Average Nusselt number or heat transfer coefficient to compare better heat transfer?
Moreza7 is on a distinguished road
I'm simulating different arrays for cylinders in a simple cross flow heat exchanger (cylindrical pipes) as shown below:
Inlet temperate(300K) is constant and the cylinders are at constant temperature(400K).
I've calculated average Nusselt on each pipe then summed all of them and finally divided it by the number of cylinders (9).
This gives me an average Nusselt number for heat exchanger. Let's call it Nu_{av}.
Nu_{av}=\frac{\sum Nu_{cylinder}}{9}
I also calculated the heat transfer coefficient of heat exchanger using the following equation:
\dot{m}c(T_o-T_i)=UA(T_s-T_i)
\dot{m}: Mass flow of fluid passing the heat exchanger
c: Specific heat of fluid
T_o: Average outlet temperature
T_i: Average inlet temperature
U: Heat exchanger coefficient
A: Total surface of all cylinders
T_s: Cylinders surface temperature
I've simulated a lot of arrays. In some cases, the average Nusselt number(Nu_{av}) is bigger and in some others, the average outlet temperature and so, the heat exchanger coefficient(U) is bigger.
My question is: Which one should be my criteria to compare cases? Average Nusselt number or heat exchanger coefficient?
Moreza7 is offline   Reply With Quote
Old   September 24, 2019, 16:55
Erik
evcelica is on a distinguished road
Something tells me you are calculating something wrong. These values shouldn't be going back and forth, they should agree with each other. U should equal Nu*k.
How are you calculating Nusselt number?
How are you calculating outlet temperature? You would want the mass flow average of temperature, not area average, or nodal average.
How do these values compare with total heat transferred? Which should be easy to get, and the most important I would think. But they should all match performance wise.
Moreza7 likes this.
evcelica is offline   Reply With Quote
Old   September 24, 2019, 18:02
Thank you! I used area average instead of mass flow average! Now by using mass flow average outlet temperature the results are better ,but still in some cases, the problem exists!
Can you tell me how can I get total heat transfered?
Is it \dot{m}c(T_o-T_i) or you mean something else?
About Nusselt calculation:
For each cylinder we have:
Nu_\theta=\frac{hD}{k}
Also, we have:
-k\frac{dT}{dn}=h(T_s-T_i)
n is the direction which is normal to the curve.
Using second equation and rewriting first equation yields:
Nu_\theta=\frac{dT}{dn}\frac{D}{T_i-T_s}
So, the average Nusselt Number on each cylinder is: (Line average)
\overline{Nu_\theta}=\frac{1}{\pi D}\oint{\frac{dT}{dn}\frac{D}{T_i-T_s}ds}
Old   October 8, 2019, 17:15
Erik
Total Heat Transferred can be obtained many ways
= areaInt(Wall Heat Flux)@CylinderSurface
Or check the .out file, and that should give you your boundary data at the end.
Or m.dot * cp * (massFlowAve(T)@Outlet - massFlowAve(T)@Inlet)
I know the definition/derivation of Nusselt. But I still don't get how you are actually calculating it, using what CEL expression exactly?
Have you looked in the FAQ's in the wiki page?
https://www.cfd-online.com/Wiki/Ansy...ficient_in_CFX
Old   October 8, 2019, 18:20
Thank you.
COMSOL gives derivatives at any direction + gradient magnitude!
Old   October 15, 2019, 09:50
Erik
Those gradients might not be best suited for your needs. Especially if you are using wall functions, and not fully integrating to the wall to calculate heat transfer. It may be giving you a nodal/cell gradient, and not a wall function gradient. I would use a different method than the gradient method.
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
How To Calculate Average Heat Transfer Coefficient in CFD-Post? Shomaz ul Haq CFX 16 November 24, 2019 19:57
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
heat transfer coefficient and nusselt number mohsen0488 Main CFD Forum 1 February 22, 2014 06:00
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
