CT
Rep Power: 10 ![]() |
Hi All!
![]() I have closed circle case analysis and is has 50 mm thick honeycomb. I don`t want to model honeycomb (due to cell number). I choosed porous zone in Fluent. When I searched something about honeycomb modelling there is no research article. Maybe I couldn`t find. Anyway I thought that modelling honeycomb by using porous zone is a correct way or should I choose different modelling way? It was my first question. The second one is if I can use porous media for modelling (hexagonal cross section) honeycomb and I want to calculate inputs but which deriving method would be best for this kind of situation? - Superficial velocity and known pressure loss.(BTW I don`t know the exact pressure values) - Ergun eqn. (or Blake-Kozeny eqn. My problem has high Reynolds number greater than 500k, internal flow) - Or Empirical eqn. for turbulent flow. Thank you! ![]() |
cfd, fluent, hexagonal holes, honeycomb, porous |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
Substituting a porous geometry with equivalent porous zone parameters | stein.robins | Main CFD Forum | 0 | September 23, 2015 15:08 |
modelling shadow of porous fluid zone in FLUENT | chris20 | FLUENT | 0 | November 13, 2013 08:13 |
Modelling sound propagation through layered porous media | nkinar | Main CFD Forum | 0 | July 4, 2010 14:45 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 15:52 |
