CFD airflow simulation of four simple objects - freelancer needed asap |
Stuart
Rep Power: 8 ![]() |
I am in need of simulating the airflow/drag of four different torpedo-shaped objects, as if they were moving through the air.
The work would involve constructing meshes for four simple cigar-shaped objects based on specifications provided, then run a CFD simulation of airflow so that drag can be analysed and compared. |
Hannes
Rep Power: 17 ![]() |
Could you please provide some further information regarding dimensions, velocities, Re, Ma, etc. ?
FluidEngineeringSolutions |
Stuart
The project is a public engagement exercise that asks the question: 'how far is it possible to throw a hotdog?' if it is thrown like an American football.
The object for CFD analysis is therefore a hotdog (in bread bun): four different designs will be made (e.g. a bun with a pointy end, a hotdog sausage that is fatter at the front, a bread bun that has fins...) for which a mesh will need to be generated. I would provide photos and measurements of the designs. The CFD analysis needs to be able to create a visual output that can be used to show how airflow and drag generated by each hotdog differs. I see that such analyses have been performed previously for soccer and American footballs (e.g. https://www.simscale.com/blog/2014/0...n-in-football/ and https://www.resolvedanalytics.com/th...l-aerodynamics ) Results will need to be in a form that allows for some kind of quantitative comparison of drag between designs, and a prediction of which design will fly the furthest in ideal conditions. I understand that such an application has varying speed and varying moving direction and thus not steady state, although for simplicity's sake a 'wind tunnel'-type steady-state analysis may be appropriate. |
Bobby
I havce good experience in CFD analysis
You can contact me on my email ID, SO we can discuss about the project. Sunilkumar.vasamsetti64@gmail.com |
Bobby
I have good experience in cfd starccm+
You can contact me@ sunilkumar.vasamsetti64@gmail.com |
Stuart
Can you give any examples of previous work please?
Bobby
External aerodynamics
Underhood thermal analysis HVAC Cabin cooling and Panel aiming HVAC component level analysis Ducts HXs (Radiator,condensor,CAC) Exhaust system Blower PQ curve generation Turbines Compressors etc.,. are the some of the projects I have worked and been working. |
Rep Power: 11 ![]() |
#9 |
mauricio
Rep Power: 18 ![]() |
A hot dog? really? This gotta be all about marking
![]() Anything more complicated than an effective drag ss subsonic calculation is way too expansive for its purpose... it should be a straightforward weekend task ![]()
Best Regards /calim "Elune will grant us the strength" |
#10 |
Stuart
Hi Calim, If this is something you are interested in doing over a weekend, please drop me a message!
#11 |
Gokul Ravi
Hello, this is Gokul. I can provide you with a good drag estimation for your hot-dog problem using my experience in OpenFoam simulation. Please feel free to contact me here: gokulravi.pgt@gmail.com.
#12 |
Stuart
This job has now been given
aerodynamics, air flow simulation |
CFD Salary | CFD | Main CFD Forum | 17 | January 3, 2017 17:09 |
Advice needed for learning CFD tools for entry level job | sidharth9426 | Main CFD Forum | 0 | December 19, 2015 02:21 |
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 19, 2015 23:40 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
Reactor simulation using CFD takes to the Internet | Mark Brennan | Main CFD Forum | 0 | April 16, 1999 05:57 |
